b20b vtec w/jun 3's not revving
Old Mar 23, 2002 | 02:21 AM
dragster's Avatar
New User
Default b20b vtec w/jun 3's not revving
for my b20b vtec, just installed jun 3's. i'm using 108 degrees cam setting but the engine's very reluctant to rev past 7500rpm.
this set-up supposedly should be able to rev happily up to 9500rpm & makes about at least 200+whp, no sweat! but mine has **** like top end
tried to advance 3 degrees intake & retard 2 degrees exhaust. but still to no avail in power making past 7500rpm.
compression is 11.6:1, bottom end fully balanced & lightened. ecu is fine, its custom obd1 program. head ported, jun racing valve-springs, 330cc injectors & upgraded fuel pump.
my car have just about everything, but isn't making power...
please advise me what to do....
Old Mar 23, 2002 | 10:40 AM
Trey's Avatar
25 Year Member
Default Re: b20b vtec w/jun 3's not revving (dragster)
have you swapped ecu's?
It might have a lower redline in the program.
Try an OEM one just to rule out any problems with the ecu you have....
Old Mar 23, 2002 | 05:56 PM
xtrafastcivic's Avatar
Default Re: b20b vtec w/jun 3's not revving (Trey)
tune them. maybe your ecu program is starving the cams up top
Old Mar 23, 2002 | 07:10 PM
Kamin's Avatar
Default Re: b20b vtec w/jun 3's not revving (XtraFastCRX)
yes my vote would be ecu
also: are you using intake header and exhaust? maybe the engine isnt getting enough air.
what about your fuel setup?
Louie_EM1
Jul 27, 2005 02:16 PM
Louie_EM1
Feb 7, 2005 10:27 PM
iperez
Jun 24, 2004 06:54 AM
slowerthanu
Mar 3, 2002 10:20 PM
