my fuel gauge is in-accurate....what can i do to fix/test it?
Old Jan 25, 2006 | 06:25 PM
hatchinprogress's Avatar
Default my fuel gauge is in-accurate....what can i do to fix/test it?
it's a 92 ls, i bought the car about a year ago (it had the problem then, but not as bad). My fuel gauge isnt working when i fill up my tank the needle says it's about 3/4 full.....but lately thats been changing also (it hasnt gone to a constant make lately) right now the needle range is about 1/4 below empty 2 3/4 full. like i said before the used to not drop that far below empty (when the needle is that low, the fuel light doesnt come on...even though it has came on before) so can someone help me out? what should i look for or test.....to try and fix the problem?
Old Jan 25, 2006 | 08:20 PM
Default Re: my fuel gauge is in-accurate....what can i do to fix/test it? (hatchinprogress)
help
Old Jan 25, 2006 | 09:39 PM
bump to end the night
Old Jan 26, 2006 | 05:15 AM
numbnuts22715's Avatar
kinda off topic but still deals with the fuel gauge..
In a 99 gsr does the fuel gauge rise really slowly after you fill upyour tank? it takes like three or four minutes for me when i fillmy tank for it to get to "full"
Old Jan 26, 2006 | 05:43 AM
nickG's Avatar
i dont really know how to test your guage..but you could use your trip guage on your odometer to keep track of mileage..you go approx the same miles on each tank..
get a helms..it should have a section to troubleshoot any problem you can think of
Old Jan 26, 2006 | 02:59 PM
Default Re: my fuel gauge is in-accurate....what can i do to fix/test it? (nickG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickG &raquo;</TD></TR><TR><TD CLASS="quote">i dont really know how to test your guage..but you could use your trip guage on your odometer to keep track of mileage..you go approx the same miles on each tank..
get a helms..it should have a section to troubleshoot any problem you can think of</TD></TR></TABLE> yeah i have been using my tripodometer but im tired of seein my tank on a 1/4 below emtpy<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr One Lane &raquo;</TD></TR><TR><TD CLASS="quote">This is all a guess. So If I'm wrong don't bite my head off for it. I don't think it's the gauge itself, but probably the electronic unit that sends the signal to the fuel gauge is defective.
Try this thread. That guy has the same problem.
https://honda-tech.com/zerothread?id=1012240</TD></TR></TABLE>thanks ill check it out
Old Jan 26, 2006 | 03:47 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (Mr One Lane)
If this doesn't fix it. Fill the tank, pull the guage needle, and set it to full.
Old Jan 26, 2006 | 04:24 PM
ComptonsF1NEST's Avatar
Default Re: (Dogginator)
does it move at all? my dad's bonneville would be empty at 1/4 tank and full at 3/4 tank, that problem was the gauge.
Old Jan 27, 2006 | 07:50 AM
Default Re: (ComptonsF1NEST)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ComptonsF1NEST &raquo;</TD></TR><TR><TD CLASS="quote">does it move at all? my dad's bonneville would be empty at 1/4 tank and full at 3/4 tank, that problem was the gauge.</TD></TR></TABLE> yeah it moves...pretty much like your dads....when i fill it up the needle is bout 3/4 and when empty(or close to it) the needle will be 1/4 below empty
sa2ms7on
Nov 7, 2012 09:34 AM
mtpktz.
Apr 19, 2007 09:33 AM
Nihilus
Feb 26, 2005 02:58 PM
90lsteg
Apr 1, 2004 12:06 PM
