white smoking out of the exhaust! help please!
Old Jan 25, 2006 | 05:35 PM
sxyflyttr's Avatar
Default white smoking out of the exhaust! help please!
hellllpppp! i garaged my prelude for about 10 months, and couldnt start it that many times because it is quite some distance from where i live. the car was in immaculate condition before i garaged it. not to say it isnt now, but when i started it the other day white smoke came out of the exhaust. i let it warm and i think it went away but when i tapped the gas in neutral some white smoke appeared again. any ideas of what my problem is. i already know i should have started it more often, but timing and so forth has made it difficult. any ideas will help, thanks
Old Jan 25, 2006 | 05:46 PM
BB6racer's Avatar
your gas probably went bad. if gasoline sits still for a long time it goes bad, thats why when people store their cars for the winter they add feul protector. these little bottles keep gas in good condition for a long time, and they can be purchased at most parts stores, and even some gas stations. all you need to do is drive the car until you empty the tank, and then just fill up with new gas. although i have heard that if you add new gas to the old gas, it will "cure the old gas, but i'm not sure on that one.
Old Jan 25, 2006 | 06:32 PM
sxyflyttr's Avatar
Default Re: white smoking out of the exhaust! help please! (sxyflyttr)
any other opinions?
Old Jan 25, 2006 | 06:51 PM
driftmaster04's Avatar
i doubt its anything to worry about its prolly just condensation building up in the block and exhaust system change the oil in and it like the other guy said put som new gas in it and i bet itll quit.
Old Jan 25, 2006 | 07:41 PM
CivicSiDriver02's Avatar
Default Re: white smoking out of the exhaust! help please! (driftmaster04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by driftmaster04 &raquo;</TD></TR><TR><TD CLASS="quote">i doubt its anything to worry about its prolly just condensation building up in the block and exhaust system change the oil in and it like the other guy said put som new gas in it and i bet itll quit.</TD></TR></TABLE>
Yep. My Civic Si did the same thing when I stored it for the winter. An oil change and fresh gas took care of the problem.
Old Jan 25, 2006 | 08:31 PM
The Weather Man's Avatar
could be a blown headgasket. You could have coolant getting into your cylinders.....if that happens you will **** white smoke.........
quick way to test - pull all of your spark plugs when the car is cold.
If all of them are dirty, and one is clean - the clean one represents that coolant is in the cylinder.
When coolant is "ignited" it turns into steam - which cleans the spark plug. Kinda like steam cleaning an engine........
Hope that helps. Good luck.
Oh, and its always a possibility. Many people think that if you have a blown head gasket - you'll just have coolant and oil mixed - thats false. There are millions of ways to break a headgasket. There are coolant passages, oil passages, and cylinder holes in a headgasket. A crack or break in any could cause a different combination of things happening.
but i don't see it being anything terrible. Just change the gas like posted above.
Old Jan 26, 2006 | 07:44 AM
flip1199's Avatar
Default Re: (TheKINGPin)
water in the combustion chamber.
Old Jan 26, 2006 | 07:49 AM
Sephro's Avatar
Default Re: (flip1199)
I say it's just moisture build up... Get some drygas and run that tank out.
If when you run it on a new tank of gas and it's still doing this... then I would start to worry...
Old Jan 26, 2006 | 08:06 AM
bdybldr's Avatar
It could be oil build up. Too much engine oil. Or it could be a cracked manifold.
crxblues
Jun 8, 2009 09:13 AM
rexfan
Dec 1, 2008 04:32 PM
sxyflyttr
Jan 26, 2006 07:54 AM
beaterman
Oct 12, 2003 07:48 PM
jazz215
Jan 26, 2003 10:44 PM
