EF Radiator
Old Jan 25, 2006 | 03:52 PM
projektcivic's Avatar
Default EF Radiator
i have an EF like 2 inches off the ground.... well i t was dark and rainy and i KILLED a dip in my car at like 25 mph... cracked the radiator...
can someone give me a hand with prices, and how to get this bitch out... and how to get another one in...
any pics/ posts would be GREATLY appreciated.
thanks
Old Jan 25, 2006 | 04:04 PM
Speed--Freak's Avatar
Try a search on the word radiator.
Old Jan 25, 2006 | 04:15 PM
Default Re: (Speed--Freak)
i did search it. and came up with nota
Old Jan 25, 2006 | 04:29 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projektcivic &raquo;</TD></TR><TR><TD CLASS="quote">i did search it. and came up with nota </TD></TR></TABLE>
i found 87 threads when i searched the archives from the ef forum.
First drain the coolant. To remove it you disconnect the upper and lower hoses, remove the brackets from the top, pull it out. Might as well replace as many coolant hoses as you can since you have to drain the coolant.
Old Jan 25, 2006 | 04:40 PM
Hondacivic90ed's Avatar
Default Re: (projektcivic)
price wise for oem is gonna be expensive, if you want honda oem go w/ http://www.hondaautomotiveparts.com (Majestic Honda) is where I got mine from roughly $250 but its oem and guarenteed to fit correctly. As far as getting it out its fairly simple, first drain whatever remaining coolant there is left in the radiator by opening the drain on the bottom of the passenger side of the radiator. Now depending on weather or not your car has a/c will change the difficulty, but either way its really easy. Remove the upper radiator hose, its easiest to just remove it altogether from the radiator and the head so that you can get your fingers in to remove other things. Now remove the bolts holding down the stock air box hose (if you still have one). Remove the 4 bolts holding down the radiator fans and remove the clips for the wire harnesses and unplug the passenger side fan and pull it up and out of the engine. Now remove the wiring at the right side of the driver side radiator fan and harness clips. Slide the driver side radiator fan towards the passenger side and then up and out, the a/c lines curl up infront of the driver side fan so you may have to temporarily unbolt the brackets that hold them down, do NOT unbolt the a/c lines from the condensor or the a/c compressor as you will have to recharge the system. Just remove bolts that will allow the lines to be temporarily moved to allow the removal of the driver side fan. Remove 4 bolts securing the radiator stays at each upper corner of the radiator. Remove the c-clip holding the overflow tube at the top of the radiator. Pull directly up on the radiator and rest it on the radiator support. Remove the lower radiator hose, it will flex enough to get it up to remove it, I found it easier to do this then to remove it from underneath as the clamp was not angled where i could get a set of pliers on it from there. Reverse removal for installation. Fill radiator w/ 50/50 mix and keep the cap removed. Start the engine and hold throttle partially open until the lower radiator hose begins to feel hot (thermostat has opened). To make sure the connections are correctly reconnected fast idle the car until the radiator fans come on. Squeeze the hoses while the thermostat is open to purge the system of air. Antifreeze will be leaking out of the open radiator at this time due to the expansion of the water/antifreeze so I usually use some rags around the radiator to absorb the excess. When both fans have turned on and then off, you can top off the radiator w/ coolant and cap it off. Now just spray down the engine bay w/ a hose to rid you of that awful coolant burning smell which you will have unless you spray it off. You're welcome.
GILBY
Apr 11, 2016 08:54 AM
4d00rEF
20
Dec 11, 2009 11:35 AM
civicdust
Apr 22, 2009 09:43 PM
