Q on fuse size for rear battery conv.
Old Jan 25, 2006 | 02:14 PM
runeminaEF9's Avatar
Default Q on fuse size for rear battery conv.
i'm currently in the process of converting my battery to the rear hatch in my EF9.
i have everything i need to do the conversion and its two thirds of the way done, but i dont know what size inline fuse or breaker i need to use for this setup. i'm not running any aftermarket audio or anything like that. the only powered accessory i have is a vafc unit. also the AC equipment and power steering has been removed as well (dont know if it has an effect on voltage). i'm sure someone here has done this and knows what i need to use. i tried the search option, but the info i was lookin for was very vague. i've got a 100 amp fuseblock now but i dont know if its enough, and the only other thing i can find for cheap is a 175 amp fuse. i can get just about any amp rating i need at the audio shop but i dont wanna have to pay 15.00 for a fuse unless i have to........any ideas fellas?
Old Jan 25, 2006 | 02:42 PM
Pee Wee's Avatar
Default Re: Q on fuse size for rear battery conv. (runeminaEF9)
you need a fuse? if so im F**ked
Old Jan 25, 2006 | 04:14 PM
Rukusmasta2's Avatar
Default Re: Q on fuse size for rear battery conv. (EF8opey)
yea i never heard that either someone else verify please
Old Jan 25, 2006 | 04:32 PM
si0385.'s Avatar
Default Re: Q on fuse size for rear battery conv. (Rukusmasta2)
http://crx.honda-perf.org/arti....html
this guy sais you should use a 60 amp but hes using a odyssey battery dunno if you need a bigger fuse for the stock battery there is a equasion to figure it out i used to know when i was heavily into car audio when i was 16-17 but i forgot it
just got a inline 60 amp fuse for my car today cuz my battery is in the trunk and i have no fuse (better safe than sorry) ill let you know how it goes ill put it in tomarow
Old Jan 25, 2006 | 04:36 PM
Eresuncabron's Avatar
Default Re: Q on fuse size for rear battery conv. (jaydeum4lyfe)
you need a bigger fuse than that
your starter probably pulls around 100-140Amps
they make machines to test starter draw
and yes you should have a fuse,
if the positive battery cable insulation wears down on your firewall for example
it's like touching the pos and neg termals with a wrench
Instant welder
it seems to me that there is no way a 60a fuse would hold up but i don't see why the guy would put that online if it didn't work...
Old Jan 25, 2006 | 05:21 PM
rsca_crx's Avatar
Default Re: Q on fuse size for rear battery conv. (Eresuncabron)
you need a fuse (or breaker) on the positive wire, within a foot of the battery.
shorting along the line before the main fuse will start a fire.
here is a diagram i made when i did mine. 100a is what you want.
Old Jan 25, 2006 | 05:24 PM
downest's Avatar
Default Re: Q on fuse size for rear battery conv. (rsca_crx)
Pic's not working Greg. He's right, you need a 100 Amp. I just did the battery in a friend's car last week and he got a distribution block with 60 amp fuses, he blew 2 of them and then decided to put a piece of metal across the block for the starter power. Not safe, I wouldn't do it, but he needed the car to go get the right fuses.
Old Jan 25, 2006 | 05:25 PM
Vtakkk's Avatar
haha I just electric taped my wires together, getto ****
Old Jan 25, 2006 | 06:08 PM
joshman's Avatar
Default Re: Q on fuse size for rear battery conv. (StupidEFs)
You definately need a fuse withing 12 inches of your postive battery terminal. I'm currently using a 100 amp ANL fuse within 6 inches of the battery terminal. You can find them at pretty much any car stereo store.
Plus they increase your bling factor like 800%.
Here is a link to the one I am currently using. You can find them for much less though.
100Amp ANL Fuse
Old Jan 26, 2006 | 01:34 AM
Default Re: Q on fuse size for rear battery conv. (joshman)
i've got an inline ANL with a 100 amp already.
Old Jan 26, 2006 | 06:00 AM
rsca_crx's Avatar
Default Re: Q on fuse size for rear battery conv. (downest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by downest &raquo;</TD></TR><TR><TD CLASS="quote">Pic's not working Greg. He's right, you need a 100 Amp. I just did the battery in a friend's car last week and he got a distribution block with 60 amp fuses, he blew 2 of them and then decided to put a piece of metal across the block for the starter power. Not safe, I wouldn't do it, but he needed the car to go get the right fuses.</TD></TR></TABLE>
i'm at work and i can see it. anyone else not see it?
on the fuse, trust me here and get a breaker if you work on things where you need to disconnect power a lot or you store your car for more then a week at a time. the breaker makes a nice switch so you dont have to monkey around with stuff. and you dont need to buy expensive anl fuses any more.
Old Feb 1, 2006 | 04:20 AM
Agreed
Old Feb 1, 2006 | 04:59 AM
teler86's Avatar
where are breakers sold?
Old Feb 1, 2006 | 07:27 AM
HondaFerris's Avatar
Default Re: Q on fuse size for rear battery conv. (teler86)
yes definately put a fuse in there...or you'll regret it down the road when your cars up in flames...
Old Feb 1, 2006 | 07:38 AM
Chase's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teler86 &raquo;</TD></TR><TR><TD CLASS="quote">where are breakers sold?</TD></TR></TABLE>
yeah...wheere
edit: would this work??
http://cgi.ebay.com/ebaymotors...wItem
Old Feb 1, 2006 | 08:53 AM
HatchBox's Avatar
Skoobie no more...
Default Re: Q on fuse size for rear battery conv. (EF8kid)
&lt; using 100 amp circuit breaker works fine
YuckyCorpse
Feb 7, 2014 07:36 AM
skata89
Audio / Security / Video
Jul 24, 2006 11:48 AM
CRX Si
Sep 14, 2003 07:42 AM
Accord15
Feb 21, 2003 09:43 PM
Nameless RB26
Jan 8, 2003 05:35 PM
