timingbelt trouble, b16
well this post is about my daily beater now a 89mod crx with a b16a1 engine, i know it is not a type-R, but after i got my dc2 and started to read in here i found out that you have a tech knowledge above average
so im trying this.
my car suddenly lack all of the little power is usually have when i was driving home from work a day, so it turned out that the timingbelt have sliped and my cam gears are a tooth off. i guess that is all the problems but i don't know yeat since i don't have access to a garage in a week or so.
but do you guys think my valves have been bendt now or something like that? the motor is all stock inside.
so i should just replace timingbelt, tensioner and water pump, and take a comp test/cyl leakdown test?
so im trying this.my car suddenly lack all of the little power is usually have when i was driving home from work a day, so it turned out that the timingbelt have sliped and my cam gears are a tooth off. i guess that is all the problems but i don't know yeat since i don't have access to a garage in a week or so.
[QUOTE=
so i should just replace timingbelt, tensioner and water pump, and take a comp test/cyl leakdown test?[/QUOTE]
i dought that u bent any valves, if u just are off a tooth.
I have an extra belt. You can have it for an Iced Soy White Chocolate Mocha w/ whip at Starbucks...and you pay for shipping. I'm tired of looking at it, and I don't use it.
i have a timingbelt and the rest is needed to do the change.
i tried to turn the motor and did not feel any resistance that could be contact between the valves and pistons. but a comp check will tell me
hellbent86
23
May 2, 2011 04:02 PM
