ECU and Intake question?
Old Mar 22, 2002 | 09:13 PM
hondacivic4g's Avatar
Default ECU and Intake question?
I have a 91 STD hatch w/ 1.5L. Will a 88 integra intake system(MPFI) bolt up to my D15?And can i use the 88 Teg ECU?
OR if I get an MPFI off another D series motor can i use the 88 Teg ECU on it, w/ a fuel regulator?
Thanks-HC4G
Old Mar 22, 2002 | 09:14 PM
89 CRX SI's Avatar
Default Re: ECU and Intake question? (hondacivic4g)
I want to know too
Old Mar 23, 2002 | 09:14 AM
eg6ajk's Avatar
ZC and D16A6 share the same patters, but do not bolt on any sohc D-series motors
for SOHC d-series only alternative is:
88-91 Civic/CRX Si
92-5 Civic DX/Si/EX/LX (Si/EX being the better of the two)
96-00 Civic EX/Si (canadian Si=USDM EX) (by far the best flowing and design wise)
you will require also 88-91 integra injectors, 88-91 Civic/CRX SI distributor
as far as ecu 88-91 civic/crx si/88-9 integra / 90-1 integra as well
for TB stick with the intake that it came from if you go with 92-00 style then 92-00 d-series and 90-00 b-series will work and h/F series as well making it large TB,
if you get 88-91 then only those will work from 88-91 civic/crx and 88-9 integra
Old Mar 23, 2002 | 10:49 AM
rice_classic's Avatar
Default Re: ECU and Intake question? (eg6ajk)
eg6ajk: you wise and knowledgable crafty bastard!!
dylaxiin
22
Oct 8, 2011 07:00 AM
19REX89
Apr 23, 2009 06:31 AM
RicedREX
Apr 18, 2003 07:32 AM
