need some ideas on what is causing my 3rd gear grind
Old Jan 25, 2006 | 11:16 AM
hondatuner20's Avatar
Default need some ideas on what is causing my 3rd gear grind
well heres my set up. 88 crx si with a b16a2 26,000 miles with a ys1 trans 70,000 miles. i have a hasport shift likage and im running the original clutch and i have a short shifter. now for the problem. like once a week ill go to put it in 3rd and it will just grind in, it goes in smoothly except for the annoying noise. my clutch is old and i believe its on its way out and i believe my input shaft bearing on my trans is done aswell being that i can here it whining as i drive. but i have been told by others that its my throw out bearing. could this mysterious once in a week or so grind be from one of these bad parts or is my tranny on its way out aswell?
Old Jan 25, 2006 | 11:22 AM
Jesterian's Avatar
24.243.141.75
Default Re: need some ideas on what is causing my 3rd gear grind (hondatuner20)
I suggest getting rid of that short shifter and finding a nice stock shifter or a non-short aftermarket, for obvious reasons.
Old Jan 25, 2006 | 12:26 PM
any other ideas i dont think my short shifter would be it because many people have them with out problems.
Old Jan 25, 2006 | 12:50 PM
ghost_ryder35's Avatar
I would try flushing the tranny and putting some synchromesh in there... prob a bad sychro
Old Jan 25, 2006 | 01:27 PM
Default Re: need some ideas on what is causing my 3rd gear grind (ghost_ryder35)
but if it was a bad syncro wouldnt it grind more the once every week to week and a half.
Old Jan 25, 2006 | 02:07 PM
d15hatch's Avatar
Most likely a bad syncro. My 4 speed grinds when I put it into third, such as yours, and it does not do it all the time, again such as yours.
Old Jan 25, 2006 | 03:03 PM
crix351c's Avatar
Default Re: need some ideas on what is causing my 3rd gear grind (d15hatch)
replacing the shifter wont do much...the only thing that a short shifter does that is bad for the tranny is it doesnt give the tranny enough time to speed up the next gear before engagement....the damage isnt "that" much more than ripping threw gears with a stock one....just dont shift as hard into that gear and definately change the fluid
Old Jan 25, 2006 | 03:19 PM
Default Re: need some ideas on what is causing my 3rd gear grind (crix351c)
sry im a newbie to transmistions how do i drain and refill the fluid?
Old Jan 25, 2006 | 03:30 PM
si0385.'s Avatar
two plugs on the right side of the tranny if you take off the passenger tire and look around where the axle is you cant miss them... 2 of them one on bottom for draining one on top for filling... drain it put plug back in the bottom plug take out top plug.. go to local chevy dealer buy 2 or 3 quarts of gm syncromsh FM (friction modified... ive heard a couple people say you need 3 quarts but i personaly only needed 2... and reach deep in your pockets the gm fm syncromesh is pretty pricey) and fill through top hole untill fluid starts running out put plug back in and tire on and drive and pray it works
Old Jan 25, 2006 | 03:32 PM
si0385.'s Avatar
Default Re: need some ideas on what is causing my 3rd gear grind (jaydeum4lyfe)
just realised you had a b-series tranny
somebody confirm the fluid amounts and where the drain plugs are ???
Old Jan 25, 2006 | 03:35 PM
ludesrv's Avatar
Same thing as the D series, all honda manuals are the same!
Syncromesh the **** out of your tranny cause you got a fucked up synchro. Trust me, they DON'T grind all the time, case my H22 tranny grinds 3rd and 5th every 10-15 shifts.
Old Jan 25, 2006 | 04:36 PM
Default Re: (ludesrv)
i understand what your saying but i mean it only grinds ever like 30-40 shifts
Old Jan 25, 2006 | 04:38 PM
Default Re: (hondatuner20)
could it be the input shaft bearing i have heard that those have caused some odd grinding issues?
Old Jan 25, 2006 | 05:33 PM
si0385.'s Avatar
if it was the input shaft bearing you would know it it would be a different kind of gring kinda like a howel when your foot isitn on the clutch than when you push down on the clutch (assuming your throwout bearing is ok) it would quiet down
Old Jan 25, 2006 | 05:47 PM
Default Re: (jaydeum4lyfe)
thats what it does my input shaft bearing is bad i was wondering if that could cause the grind
Old Jan 25, 2006 | 07:01 PM
i would say try flushing it and filling with synchro mesh... if it still does it rebuild the tranny or buy a new one
Old Jan 25, 2006 | 07:12 PM
bagpipe goatee's Avatar
why would the imput shaft bearing cause it to grind? it's just turning... (i don't mean to be rude and don't want to sound like an ***, i just had to sit an hour and explain to a kid how a bad clutch will not cause a tranny to grind unless it's dragging. and obviously a bad clutch doesn't drag)
Old Jan 26, 2006 | 06:08 AM
Default Re: (bagpipe goatee)
idk someone on h-t said that after they replaced theirs their second gear grind went away.
Old Jan 28, 2006 | 09:47 AM
oooh it makes me so mad it grinded this mourning on my last shift into third before would get home. i hate that feeling in the shifter of it grinding.
tgraeter7
Nov 9, 2013 04:38 PM
ronman92
Apr 17, 2003 08:26 PM
twkdCD595
Apr 7, 2003 09:02 AM
threatcon13
Aug 7, 2001 04:20 PM
