cable tranny fluid
Fill it until it comes out the fill whole when the car is level. Let it drain out until nothing comes out.
It's full. Use 10w30 oil, Honda had that stuff from factory in there. Adleast, all the ones over here.
but i need to know about how many quarts it is, i put in 2 quarts in before and it would not go into any gears and just grind, i just attached the tranny to the motor and want to make sure i had the right amount of fluid in there. the only other thing i can think of is that i might have forgot to put a throw out bearing in. please i need to know approximate amount of fluid that goes in the tranny, and would not having enough fluid cause it to grind?
it's probably about two quarts, you can always check the level by sicking your finger in and seeing how close the oil is to the top, I don't think it's going to hurt anything if you fill it all the way up.
i just put some in mine while jacked up about a foot and it only used one and a half of
AMSOIL
10-40 i am sure i will need more once i lower it back down... but 2 should be plenty to make it run out...
AMSOIL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teler86 »</TD></TR><TR><TD CLASS="quote">but i need to know about how many quarts it is, i put in 2 quarts in before and it would not go into any gears and just grind, i just attached the tranny to the motor and want to make sure i had the right amount of fluid in there. the only other thing i can think of is that i might have forgot to put a throw out bearing in. please i need to know approximate amount of fluid that goes in the tranny, and would not having enough fluid cause it to grind?</TD></TR></TABLE> You have other issues if your tranny wont go into gear with 2qts in it.
you got some major issues man if you had no fluid in there it would still shift, your making it sound like you got an automatic them don't work unless you got the proper fluid and level in it
could be a fucked up pressure plate... check all the teeth and make sure none are bent or loose... this happened to me.. got a new pressure plate and it shifts like butter!
professorman
Jan 12, 2003 06:40 AM
