ABS light... intermittent in 95SE
Old Jan 25, 2006 | 09:20 AM
axtran's Avatar
Default ABS light... intermittent in 95SE
ok, sometimes when i start the car (usually when its warm) the ABS turns on. other times, i have to drive a bit first (like 15 mins) for it to turn on, and even sometimes it doesn't turn on. do you guys think it could be a faulty relay? is there a way to tell if the ABS unit is failing? and if so, is it unsafe (like brake system fully dependent) on ABS?
ps i have a 4th gen, 95SE
Old Jan 25, 2006 | 09:58 AM
The Weather Man's Avatar
change your relay - it might be going out.
To test it, take out the headlight relay(in the morning of course) and switch it with the ABS relay. If the light doesn't come on again - its the relay.
My headlights used to go in and out sometimes - found out it was the relay......
But right now, I took my ABS relay out - if you don't drive crazy, i don't see a problem with it. But it only costs like $13 for a new relay.
Old Jan 25, 2006 | 10:02 AM
kulrevon's Avatar
Default Re: (TheKINGPin)
why dont you just check the abs code?
Old Jan 25, 2006 | 10:23 AM
axtran's Avatar
Default Re: (kulrevon)
i have no idea how a honda abs code system works. i'm native to vws! i love my prelude though...
abs relay ... located in the engine compartment? i see two that are identical, would these be headlight / abs?
Modified by axtran at 3:33 PM 1/25/2006
sonicxtacy02
Nov 17, 2007 06:20 AM
NorthernXposure
Sep 20, 2007 12:02 PM
M2B4
Oct 18, 2006 07:46 PM
