Electrical Issue Please Look...searched!
Old Jan 25, 2006 | 08:19 AM
red_EF9Si's Avatar
Default Electrical Issue Please Look...searched!
Ok, heres the deal. I'm having some electrical issues with my 90 hatch.
dash lights dont work, taillights dont work...same with driving lights. The fuse isn't blown. I even replaced it with another but still no luck. I just get no power to those things and it sucks cuz i cant drive at night. Is there a relay or breaker of some sort that controls those things? Is there a method to tracing shorts in the system? Any input is appreciated. Thanks in advance.
Old Jan 25, 2006 | 12:56 PM
red_EF9Si's Avatar
bump, need to know.
Old Jan 25, 2006 | 01:28 PM
ludesrv's Avatar
You are probably grounding out under your dash? Was the car a hack job when you got it? Had a shitty alarm at some point?
My 93 Sr-V grounds out once in a blue moon from a shitty alarm. Kills the engine.
Old Jan 25, 2006 | 01:49 PM
mrsuburban's Avatar
Default Re: Electrical Issue Please Look...searched! (red_EF9Si)
Edit that part out where you changed a fuse that wasnt blown
Sounds like you have a wire problem. Got Mice?
Old Jan 25, 2006 | 03:36 PM
red_EF9Si's Avatar
nah, no mice. just roaches the size of cats. bump for more info!
Old Jan 25, 2006 | 04:24 PM
Eresuncabron's Avatar
Default Re: (red_EF9Si)
Yeah, You definately have a wiring problem, I might be able to get you a wiring diagram if you want one. Do you know how to diagnose an electrical circuit with a volt meter?
Old Jan 25, 2006 | 05:54 PM
red_EF9Si's Avatar
Default Re: (Eresuncabron)
who u callin cabron, cabron?
a wiring diagram would help me out a great deal, as for the volt meter...i've used them before, but i'm no expert. care to give me a quick run-down? por favor cabron
Old Jan 25, 2006 | 09:24 PM
SiAutoX's Avatar
check your dash dimmer switch (should be on left side of dash) pull it out and make sure all your wires are connected. I had same problem and went searchin, pulled it out and one wire was loose, re-connected it and it worked. try that and see
Old Jan 26, 2006 | 07:35 AM
red_EF9Si's Avatar
Default Re: (EF'n Turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF’n Turbo &raquo;</TD></TR><TR><TD CLASS="quote">check your dash dimmer switch (should be on left side of dash) pull it out and make sure all your wires are connected. I had same problem and went searchin, pulled it out and one wire was loose, re-connected it and it worked. try that and see</TD></TR></TABLE>
thanks, ill try that tonight.
Old Jan 31, 2006 | 02:55 PM
Shiet well i forgot to look up a wiring diagram i'll try to do that tm.
check for high resistances over connectors/clips as well as voltage drop over things like the dimmer switch,
voltage drop is when you test to see how much voltage is lost is a specific portion of your circuit you need to do that test with the power on.
put the positive and neg probes on either side of what you wanna test
but put the positive lead on the "more positive" side of what you are testing, just like resistance/ ohm check
this can sometimes pick up things that the ohmmeter cannot.
your voltage drops should be less than .5 all around basically, there may be some exceptions, like things with lamps in them
Good luck
Old Jan 31, 2006 | 09:41 PM
red_EF9Si's Avatar
thanks but i fixed the problem already. turns out my steering column combo switch was bad. luckily i had an EF shell at my other house with a working one.
jdmem205
Aug 31, 2012 03:07 PM
wxy117
Mar 11, 2008 01:17 PM
g0tsilkk
Apr 23, 2006 08:15 PM
lsvtec_sol
Oct 11, 2004 02:20 PM
