GSR with ls tranny :(
Old Jan 25, 2006 | 05:05 AM
Danziver's Avatar
Default GSR with ls tranny :(
I just bought a gsr swap but the tranny was broken due to a wreck and im going to have to use my ls tranny till i can find one. I just wanted to get some opinions on how it will drive. I know it wont have the acceleration of a gsr but anything else anyone noticed. I found 2 other threads on this topic but they didn't have many replies, hopefully i can get more experiences with this one. thx
Old Jan 25, 2006 | 05:14 AM
LSvtec03's Avatar
Default Re: GSR with ls tranny :( (Danziver)
it will definately feel slower. other than that, not much of a difference.
Old Jan 25, 2006 | 06:21 AM
LoseRPunKx182's Avatar
Default Re: GSR with ls tranny :( (LSvtec03)
1st and 2nd gear's fine..after that the gsr tranny ftw
Old Jan 25, 2006 | 08:33 AM
sleeperteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Danziver &raquo;</TD></TR><TR><TD CLASS="quote">I just bought a gsr swap but the tranny was broken due to a wreck and im going to have to use my ls tranny till i can find one. I just wanted to get some opinions on how it will drive. I know it wont have the acceleration of a gsr but anything else anyone noticed. I found 2 other threads on this topic but they didn't have many replies, hopefully i can get more experiences with this one. thx</TD></TR></TABLE>
good luck with that man... let us kno how it goes because i might be doing the same thing if i cant solve my problem. im going to buy a gsr motor and run it with my ls tranny until i can get a new tranny. i heard it will run fine except your gonna have some long *** gears.
Old Jan 25, 2006 | 08:38 AM
Spec R's Avatar
Default Re: GSR with ls tranny :( (sleeperteg)
1st and 2nd gears are the same numerically on the GSR and LS tranny. The difference there is the final drive (4.4 vs. 4.26). After that the GSR has shorter 3rd 4th and 5th gears (higher numerically).
I have an LS with a GSR tranny, and yes the difference feels great, but honestly its not that super special. your gsr engine has more than enough grunt to make up for it. if u had a b16 with an LS tranny, then its a different story.
Old Jan 25, 2006 | 08:45 AM
sleeperteg's Avatar
Default Re: GSR with ls tranny :( (Spec R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spec R &raquo;</TD></TR><TR><TD CLASS="quote">if u had a b16 with an LS tranny, then its a different story.</TD></TR></TABLE>
how so? just curious...
Old Jan 25, 2006 | 08:47 AM
Danziver's Avatar
I will be using a fidanza 7lb flywheel so hopefully it help a little. I found the swap engine, ecu, and wiring harness for 900$ and couldnt pass it up.
Old Jan 25, 2006 | 09:01 AM
LSvtec03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperteg &raquo;</TD></TR><TR><TD CLASS="quote">how so? just curious...</TD></TR></TABLE>
b16s have low torque, esp. for a honda. so they really rely on their short trannies to get them moving. slapping an ls tranny on their is the kiss of death.
Old Jan 25, 2006 | 09:37 AM
sleeperteg's Avatar
lol @ kiss of death... right on for the info tho...
see you learn somethin new everyday haha...
Old Jan 25, 2006 | 09:48 AM
Usagi Yojimbo's Avatar
From: Dont say my car is topless say the titties is out
Couldn't you just swap cases from the ls to the gsr?? arent they the same?? I ask because i have a jdm itr swap and i recently broke the bolt housing that holds the tranny to the tranny mount. and i thought that it would be cheaper to just get an ls case and swap out the gears and oem lsd. Or can't i do that??
Old Jan 25, 2006 | 11:12 AM
veilsides2000's Avatar
I ran an LS tranny in my gs-r for about 8 months because i couldnt get a hold of a gs-r tranny. It's a big difference but nothing crazy. your car will drive fine but the fourth and fifth are reallly long!!! good for gas mileage. P.S my third gear went later and i had to always shift from second to fourth but no problems.
Its does suck to have that tranny compared to the gs-r trans but its not realle that bad.
GOOD LUCK
Old Jan 25, 2006 | 11:26 AM
sleeperteg's Avatar
Default Re: GSR with ls tranny :( (veilsides2000)
how does it pull when vtec engages?
Old Jan 25, 2006 | 12:44 PM
Danziver's Avatar
Default Re: GSR with ls tranny :( (Usagi Yojimbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Usagi Yojimbo &raquo;</TD></TR><TR><TD CLASS="quote">Couldn't you just swap cases from the ls to the gsr?? arent they the same?? I ask because i have a jdm itr swap and i recently broke the bolt housing that holds the tranny to the tranny mount. and i thought that it would be cheaper to just get an ls case and swap out the gears and oem lsd. Or can't i do that??</TD></TR></TABLE>
I was wondering about this b/c the wreck cracked the motor mount part of the tranny and some of the housing.
Old Jan 25, 2006 | 05:31 PM
Danziver's Avatar
How hard would it be to swap tranny cases?
Old Jan 25, 2006 | 06:17 PM
92gisser's Avatar
I've been running an LS tranny on my GSR since the day I got it...I say it's fine. *shrug*
Old Jan 25, 2006 | 06:20 PM
I don't think it would be that hard. In another thread someone was saying all b series trannies are interchangable. so i figure I'll just use the parts i need from the ls tranny and mate it to my ITR tranny. ( I've called around and it seems to run about $550-$600 it change from one case to the other. this is in socal though)
Old Jan 25, 2006 | 07:19 PM
LSvtec03's Avatar
Default Re: (92gisser)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92gisser &raquo;</TD></TR><TR><TD CLASS="quote">I've been running an LS tranny on my GSR since the day I got it...I say it's fine. *shrug*</TD></TR></TABLE>
that sucks. 92-93 gsrs come with one of the most saught after trannies. i bet if you've driven it with one, you wouldnt call any ls tranny 'fine.'
Old Jan 25, 2006 | 07:46 PM
MrMike's Avatar
Default Re: (LSvtec03)
u'll be getting some good gas milleage with an LS trans
Old Jan 25, 2006 | 08:31 PM
LSvtec03's Avatar
Default Re: (MrMike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrMike &raquo;</TD></TR><TR><TD CLASS="quote">u'll be getting some good gas milleage with an LS trans </TD></TR></TABLE>
probably about the same.
Old Jan 26, 2006 | 05:44 AM
Danziver's Avatar
I know that 3rd gear is where the gsr shines, how do you think it would be in the ls? And also what do you guys think i should do while the engine is out (Timing belt, water pump, ect) the engine has 120k on it. thx
Old Jan 26, 2006 | 06:12 AM
VtecAdvantage's Avatar
Default Re: (Danziver)
I've herd that the gearing on the LS tranny will drop your rpms too low- screwing with your beautiful vtec.
How much of a difference is there between the GSR and ITR other than the LSD? I wonder if it would be better if you went ahead and got the ITR tranny.
Old Jan 26, 2006 | 06:14 AM
be.twenty's Avatar
LS will work fine.... but find another GSR tranny
Old Jan 26, 2006 | 06:30 AM
LSvtec03's Avatar
Default Re: (VtecAdvantage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecAdvantage &raquo;</TD></TR><TR><TD CLASS="quote">I've herd that the gearing on the LS tranny will drop your rpms too low- screwing with your beautiful vtec.
How much of a difference is there between the GSR and ITR other than the LSD? I wonder if it would be better if you went ahead and got the ITR tranny.</TD></TR></TABLE>
itr is shorter
Old Jan 26, 2006 | 06:45 AM
Spec R's Avatar
ALL US ITR's had the same gearing as B16's did. the 98 up JDM ITR had the 4.78 final drives.
the mileage should improve with a LS tranny if u drive on the freeways a lot. at 80 mph an LS tranny is around 3200-3300rpm and a GSR is 4000, b16 with 4.4 fd is 4500, itr with 4.78 is woooo hiiiigh..
Modified by Spec R at 7:45 AM 1/27/2006
Old Jan 26, 2006 | 07:05 AM
jomama's Avatar
yeah, your gas mileage would be better, rpms would be lower on the higher gears at cruising speed as noted earlier, and if anything... the noise level will be lower
