Lights out: Climate Control and Gauge Cluster...
Old Jan 25, 2006 | 01:27 AM
Lei Siew Long's Avatar
Default Lights out: Climate Control and Gauge Cluster...
My friend's 1992 Civic CX had an intermittent problem with the lights in the gauge cluster and climate control going in and out simultaneously.
Now, both units are out completely. Any suggestions to resolve this matter?
Old Jan 25, 2006 | 01:51 AM
ekb16's Avatar
check fuse
Old Jan 25, 2006 | 02:55 AM
Default Re: Lights out: Climate Control and Gauge Cluster... (Lei Siew Long)
that has been done. and since the problem was intermittent, the fuses wouldn't be a factor.
Old Jan 25, 2006 | 11:46 AM
onepoint6i's Avatar
loose pin fit
Old Jan 25, 2006 | 09:06 PM
Default Re: Lights out: Climate Control and Gauge Cluster... (onepoint6i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onepoint6i &raquo;</TD></TR><TR><TD CLASS="quote">loose pin fit</TD></TR></TABLE>
do you mean a loose harness either on the gauge cluster or climate control unit?
Old Jan 26, 2006 | 01:47 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Trace the illumination wire. Check at your dimmer switch first.
Old Jan 26, 2006 | 04:44 AM
Default Re: Lights out: Climate Control and Gauge Cluster... (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">Trace the illumination wire. Check at your dimmer switch first.</TD></TR></TABLE>
Thanks. i'll give that a shot.
Old Jan 26, 2006 | 09:48 AM
turboman's Avatar
did you replace the dimmer switch? Thats what I had to do with mine
Old Jan 27, 2006 | 12:56 PM
Default Re: Lights out: Climate Control and Gauge Cluster... (turboman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboman &raquo;</TD></TR><TR><TD CLASS="quote">did you replace the dimmer switch? Thats what I had to do with mine</TD></TR></TABLE>
no, not yet. but, was your problem similar to this situation?
Old Jan 29, 2006 | 09:30 PM
Yep, it was the dimmer switch. thanks for everyone's help and suggestions.
JDM_EK_wanabe
Sep 28, 2006 02:03 PM
tuyettam
Mar 31, 2006 02:56 PM
terribl3jon
May 1, 2005 04:03 PM
93VAhatch
Jan 13, 2003 06:23 PM
