sohc d series head gaskets, all the same?
Old Jan 25, 2006 | 12:02 AM
AJxr's Avatar
Default sohc d series head gaskets, all the same?
i have a brand new d16a6 gasket kit, can i use it for a mini me swap on a d16a6 with d16z6 head/IM and d16a6 tb.
Old Jan 25, 2006 | 02:06 AM
davens's Avatar
Default Re: sohc d series head gaskets, all the same? (AJxr)
Most, if not all, of them are interchangeable.
However, check the material that the a6 gasket is made of...the original design, the composite fiberous material is known to leak very easily. Honda's solution for a long time was to simply use the 92+ d16z6 all metal gasket. It's hair thinner causing the slightest increase in compression ratio, but lasts much longer.
Someone was recently saying that Honda started selling a headgasket that is all metal and the same thickness as the original A6 gasket...I can't verify this but its a possibility.
Long story short...if you use that crap material, you'll be more inclined to have a leaking headgasket. Use the metal gasket.
...and use some ARP head studs. The combination of better metallurgy and the stud design make them better than regular head bolts. The metal gasket and ARP studs make for an excellent quality seal.
redright9
Jan 17, 2011 08:40 AM
krysted9354
Mar 23, 2009 07:22 PM
chiliredDX
Sep 4, 2006 03:24 PM
BoostNEF
Jul 10, 2005 11:52 PM
Layziebtnh055
May 18, 2004 10:46 AM
