HELP... what kind of mounts?
Old Jan 24, 2006 | 11:06 PM
marc-111's Avatar
Default HELP... what kind of mounts?
i have a 1990 wagon and i have just swapped a 96 d16y7 on it. I'm using a si trans but my only problem is the engine mount? from what car would i use?
BTW i can no longer use the stock engine braket from the old engine coz i need to cut it off to pull down the engine
Old Jan 25, 2006 | 12:05 AM
Nerologic's Avatar
what engine mount are u talking about?
Old Jan 25, 2006 | 12:14 AM
marc-111's Avatar
Default Re: (Nerologic)
the driver side (engine mount)
coz all other mounts are on the crx si trans
Old Jan 25, 2006 | 06:27 AM
marc-111's Avatar
Default Re: HELP... what kind of mounts? (marc-111)
any?
Old Jan 25, 2006 | 07:59 AM
91 ef sedan's Avatar
u have 2 use the wagons braket on the block and the old mounts
Old Jan 25, 2006 | 10:27 AM
marc-111's Avatar
Default Re: HELP... what kind of mounts? (lady bug)
thats the prob i had to cut it off coz the bolt was already rusted to the mount
Old Jan 25, 2006 | 10:32 AM
ludesrv's Avatar
You should of impacted the bolt. They DO break free. I took out 16 year old bolts with breaker bars...
You DO need the use the old engine mount, so hope to it and go get one from a scrap yard. Any 88-91 engine mount SHOULD do, but the wagon I'm not 100% sure on.
Old Jan 25, 2006 | 10:40 PM
marc-111's Avatar
Default Re: (ludesrv)
o crap i guess i wont finish my swap for a while till i find a engine bracket for this one locally
Old Jan 25, 2006 | 11:20 PM
Nerologic's Avatar
Default Re: (marc-111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">You should of impacted the bolt. They DO break free. I took out 16 year old bolts with breaker bars...
You DO need the use the old engine mount, so hope to it and go get one from a scrap yard. Any 88-91 engine mount SHOULD do, but the wagon I'm not 100% sure on.</TD></TR></TABLE>
yeah thats what u need for the swap, u need the bracket that mounts up to the block (2 14 mm bolts) and the top mount also for that bracket...
Old Jan 25, 2006 | 11:37 PM
marc-111's Avatar
ok thanks! will try to look for one maybe tom i could get one locally
dwerpk
Dec 25, 2006 11:22 PM
Civic168
Suspension & Brakes
Feb 28, 2006 09:21 PM
BGWarren
Feb 13, 2006 06:19 AM
2000DX
Jun 23, 2004 11:15 PM
hardware17
May 23, 2002 08:50 AM
