91 ls teg cluster swap into a dx ef hatch?
Old Jan 24, 2006 | 10:04 PM
CR-V-tech's Avatar
Default 91 ls teg cluster swap into a dx ef hatch?
is this possible and if so does anyone have the wiring diagrams and pinouts
Old Jan 25, 2006 | 12:06 AM
Nerologic's Avatar
why...
im sure someone had done it, but i dont see an advantage over and si one...
Old Jan 25, 2006 | 05:14 AM
CR-V-tech's Avatar
Default Re: (Nerologic)
cuz i got one and i've seen it done on here, but its been over a yr or so, fit's well if you do some adjusting
Old Jan 25, 2006 | 02:11 PM
CR-V-tech's Avatar
Default Re: (CR-V-tech)
bump for more info
Old Jan 25, 2006 | 04:15 PM
Rukusmasta2's Avatar
ur goin to need a 90-91 crx gauge hood i think...im lookin for one myself for my 00si cluster swap
Old Jan 25, 2006 | 06:23 PM
CR-V-tech's Avatar
Default Re: (Rukusmasta2)
bump again 4 more info
Old Jan 25, 2006 | 07:28 PM
VtecSyndrome's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CR-V-tech &raquo;</TD></TR><TR><TD CLASS="quote">bump again 4 more info</TD></TR></TABLE>
It should not be hard, just follow the OEM wire diagrams in a Helms manual or something like it and repin the EF wires from your harness to the DA harness, basically should be plug and play.
I have an LS cluster also and since it does have a 140 mph limit I may do it, all though I think I ultimately want to install a '99-00 Si cluster in the future so I may not go with the LS setup. Do a search for "cluster" or "cluster install" in the Archives and in the recent topics and you will find all the info you need.
Old Jan 26, 2006 | 03:29 PM
CR-V-tech's Avatar
Default Re: (VtecSyndrome)
any body else?
Old Jan 27, 2006 | 03:56 PM
CR-V-tech's Avatar
bump for more info
Old Jan 28, 2006 | 03:46 PM
CR-V-tech's Avatar
Default Re: 91 ls teg cluster swap into a dx ef hatch? (CR-V-tech)
bump
Old Feb 13, 2006 | 04:03 PM
CR-V-tech's Avatar
bump i know this has been done before and I need to know where to trim to fit the cluster into the dash
Old Feb 15, 2006 | 02:20 PM
CR-V-tech's Avatar
BUMP
tast2s
Aug 23, 2012 08:21 PM
KeithsWhite
Jan 5, 2012 06:11 PM
quickscrx
Mar 16, 2010 01:44 PM
B6tizzleHatch
Jul 10, 2006 02:47 PM
91bluehatch
Feb 20, 2005 03:32 PM
