What size tires?
Old Jan 24, 2006 | 09:45 PM
jsull.'s Avatar
Default What size tires?
Ok I picked up a set of 15 inch Rota Auto-X's and wrapped em with Nitto NT450's 205-55-15's. Now in the front they clear the fenders with having camber no problem at all. But in the rear I'm having rubbing issues, I need new suspension, but regardless the tires are too fat. So my question is what size tire should I pick up so that it will clear the rear fender lip and tuck in.
Front
http://img.photobucket.com/alb...1.jpg
Rear
Thanks for your help
Old Jan 24, 2006 | 09:54 PM
tyro's Avatar
Default Re: What size tires? (jsull.)
205/50/15 or 195/50/15 seem to be the ticket..
Old Jan 25, 2006 | 03:18 AM
Tippyman's Avatar
Looks nice, too!
Old Jan 25, 2006 | 05:06 AM
crx_88_si's Avatar
wrong offset from the looks of it. Even the rims are outside. and 205mm is the width, 50 or 55 should not change overall width.
Old Jan 25, 2006 | 05:16 AM
S2SLOW's Avatar
Default Re: (crx_88_si)
I ran 195-45-15 but it was dumped!!!!! But it does appear to have the wrong offsets!!!
Old Jan 25, 2006 | 06:36 AM
TrueNorthStar's Avatar
You could just take a nice wooden baseball bat and roll the fender lip out.
Old Jan 25, 2006 | 07:18 AM
rbjeepthing's Avatar
195/50-15 is the correct size to maintain the same over all diameter as from factory. You are actually 2 sizes too big. Just incase people are wondering this is how tire sizes work.
195/50-15
195=Width In MM
50=Percentage of width
15=Rim Diameter
Now as you can see you have gone up actually two tire sizes since you added width and percentage to your tires. Get the proper size and you'll be fine. Also you spedometer will be off quite a bit with your current set-up. If you are looking for a wider tire then 205/45-15 would be equal to factory diameter.
Modified by rbjeepthing at 2:03 PM 1/25/2006
Old Jan 25, 2006 | 08:01 AM
Pee Wee's Avatar
Default Re: What size tires? (rbjeepthing)
why did you run a 55. your tires are the same size as a 225 50 15 without the extra width
http://www.miata.net/garage/tirecalcold.html
Old Jan 25, 2006 | 01:10 PM
Default Re: What size tires? (EF8opey)
I posted a photo of the differences between tires I used the factory SI size as a baseline.
Old Jan 25, 2006 | 03:05 PM
jsull.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman98 &raquo;</TD></TR><TR><TD CLASS="quote">Looks nice, too!</TD></TR></TABLE>
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">wrong offset from the looks of it. Even the rims are outside. and 205mm is the width, 50 or 55 should not change overall width.</TD></TR></TABLE>
I think the main reason that they look to be on the outside is because I have it raised up and since the tires are quite large.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrueNorthStar &raquo;</TD></TR><TR><TD CLASS="quote">You could just take a nice wooden baseball bat and roll the fender lip out.</TD></TR></TABLE>
Yea I plan on doing that, i know that right now I want a different size tires plus that to make it clear no problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rbjeepthing &raquo;</TD></TR><TR><TD CLASS="quote">195/50-15 is the correct size to maintain the same over all diameter as from factory. You are actually 2 sizes too big. Just incase people are wondering this is how tire sizes work.
195/50-15
195=Width In MM
15=Rim Diameter
Now as you can see you have gone up actually two tire sizes since you added width and percentage to your tires. Get the proper size and you'll be fine. Also you spedometer will be off quite a bit with your current set-up. If you are looking for a wider tire then 205/45-15 would be equal to factory diameter.</TD></TR></TABLE>
Thanks for all your help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8opey &raquo;</TD></TR><TR><TD CLASS="quote">why did you run a 55. your tires are the same size as a 225 50 15 without the extra width
http://www.miata.net/garage/tirecalcold.html</TD></TR></TABLE>
I ran with the 55, since I got a good deal on them. I didn't think that this problem would occur, because on my ef hatch I had tires that were much bigger than this and it never rubbed.
Old Jan 26, 2006 | 10:04 AM
I've been running a 215/45/16 on my CRX. After the baseball bat....= no rubbing
Old Jan 26, 2006 | 11:00 AM
crx_88_si's Avatar
the back wheel still doesnt look right to me. take some pics from different angles. looks like a fat 17" rim (i know it's not), but it looks VERY out of place.
integracura
Jan 2, 2007 06:06 PM
mrtrinh
Honda Civic (2001 - 2005)
Jun 29, 2006 04:59 PM
Sic_DA_Nine
Apr 1, 2006 04:58 AM
93civicsedan
Nov 26, 2004 10:53 AM
snowman
Jan 25, 2002 12:43 PM
