b18 into a 91 hf HELP
I have a b18 and a ls trans and I would like to drop it into my 91 crx hf but need to know the other parts I will need swap this engine in please help me out I have looked all over the net for a site that will help but no luck I would love to get a complete list of the things needed to make this swap happen
thanks everyone
Tim
thanks everyone
Tim
No way you searched..
-b series mount kit into a 88-91 civic/crx
-pre made shift linkage for the swap or cut and re-weld an integra one
-Make a big dent in the inner fender for alternator clearence
-90-93 integra axles,remove the dust ring inside the knuckle and rubber ring on the axle(s)
-Dx/SI/EX/LX hubs,,The HF ans STD are to small..
-90-93 integra rear mount bracket
What year is the motor? If its 90-91 there's no problem,,But if 92 + youll have to convert your car to whatever obd the motor is or convert the motor to obd0 and get obd0 pr4 ecu..
Check this site out for more info..http://www.norcalcrx.org/droppedcrxsi/B16a.htm
and if running obd0 you need the fuel pressure control solenoid for the vacuum lines.. everyone misses that one... lol i just went through this lol or convert to obd1
!SEARCH!
JDMshit.com
gives you a nice list of what you need
!SEARCH!
JDMshit.com
audiopipematt88
Nov 13, 2008 06:44 PM
hybridrexsir
Apr 10, 2003 02:46 PM
Rob!
17
Jan 3, 2002 04:05 PM
