88-89/90-91 Cluster Question
Old Jan 24, 2006 | 07:37 PM
1989CivicSi's Avatar
Default 88-89/90-91 Cluster Question
I'm looking to pick up a JDM or UKDM gauge cluster, and I was wondering...will a 90-91 JDM/UKDM gauge cluster work in a CDM/USDM 89' Civic hatchback Si? If so, could anyone link me or post up the wiring diagrams? Searched, and all I could find were writeups/threads on 90-91's.
Thanks!
Old Jan 24, 2006 | 08:02 PM
Default Re: 88-89/90-91 Cluster Question (1989CivicSi)
bump, anybody?
Old Jan 25, 2006 | 01:28 AM
Really early morning bump for an answer.
Old Jan 25, 2006 | 04:48 AM
crx_88_si's Avatar
JDM SIR's had an electronic VSS (fyi)
Old Jan 25, 2006 | 05:49 AM
Default Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">JDM SIR's had an electronic VSS (fyi)</TD></TR></TABLE>
Thanks, already knew that...but assuming that I get a newer Civic VSS and the appropriate connectors, would a 90-91 JDM SiR cluster work in my 89' CDM HB?
Old Jan 25, 2006 | 06:10 AM
crx_88_si's Avatar
Default Re: (1989CivicSi)
ya, wont just plug in tho, you need to wire in the Sir cluster plugs.
I think you might also have to split the vss signal to go to two locations. 1. the cluster 2. the ecu.
search for "sir cluster"
Old Jan 25, 2006 | 01:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">ya, wont just plug in tho, you need to wire in the Sir cluster plugs.
search for "sir cluster" </TD></TR></TABLE>
Yeah, I have, and it seems to be the same for the 90-91's...plugging into the ECU that is. So it'll work on my 89' Civic Si hatchback?! Just a final verification before I drop the money on one .
Old Jan 25, 2006 | 01:47 PM
Stunna MIKE's Avatar
Want to buy my EDM cluster for 88-89 ?
http://hondamarketplace.com/zerothread?id=1478807
Old Jan 25, 2006 | 01:50 PM
Default Re: (Aaron EF9)
Possibly if you still have it in a week or two. Really just looking to see what's out there right now.
My wtb thread: https://honda-tech.com/zeropost...04600
The EDM cluster uses the cable driven VSS, right?
Old Jan 25, 2006 | 01:54 PM
wickedEFguy's Avatar
I don't know if this will help but here goes...
I purchased a 90 EDM cluster for my 90 CRX Si and instead of rewiring everything I took the guts out of the EDM cluster and put it into the USDM cluster. Turned my car on and everythign works like a charm.
I'm sure the same thing would apply to you if you did the same thing. Well at least I would hope so
Old Jan 25, 2006 | 01:58 PM
Default Re: (wickedEFguy)
Thanks, I'll keep that in mind. I'm leaning more towards the JDM SiR cluster look though...centered speedo, tach to the left, and everything else to the right. I just can't seem to get used to the "older styled" clusters we have in our Civic's/CRX's...I'll admit that the centered temp gauge is safer though.
Old Jan 25, 2006 | 02:24 PM
drachir's Avatar
To answer your questions 88-89 clusters work best in 88-89 crx's. 90-91 clusters work best in 90-91 crx's. The hood shapes are different - 90-91 is more rounded so you'll need that if you want to run a 90-91 in your 88-89. Don't quote me on this but I believe some of the pinouts are different between the two cluster generations as well.
EDM clusters use a cable VSS. JDM sir clusters use an electronic VSS. I just installed a JDM sir cluster in my car yesterday (I just have to finalize the connections now) and it was probably a lot more work than a UKDM would have been. I like it a lot better though.
Good luck with your cluster search.
B16Blake
Nov 10, 2009 10:15 PM
Sean @ ESG
Oct 4, 2008 06:45 PM
Iceycrx
Mar 26, 2006 06:36 AM
jdm92eg
Aug 14, 2005 06:02 PM
jdmhondas
Oct 1, 2004 02:17 PM
