Noise Behind Gauages
Old Jan 24, 2006 | 07:29 PM
saikouEF8's Avatar
Default Noise Behind Gauges
Sup ...I have an 88 crx dx... I have a some bolt on mods done to the stock setup, but nothing major as its my daily driver/ project for work.... aside from that, im doing the typical b16 swap this summer... moving on...
for a week now i have been getting this high pitched oscillating squeeking and crackling from behind the gauges... i know its not my belts and the sound gets louder and more annoying the faster i drive... ... i thought it had to do with the cold weather, but even in nice weather it makes the noise. any ideas what it may be and or how to fix this? thanks...
Modified by saikouEF8 at 9:47 PM 1/26/2006
Old Jan 24, 2006 | 07:35 PM
1989CivicSi's Avatar
Default Re: Noise Behind Gauages (saikouEF8)
Sounds like that one cable behind the cluster. May need to grease the cable or replace your cluster. Forgot the technical name for it though, having a brain fart.
Old Jan 24, 2006 | 07:39 PM
saikouEF8's Avatar
Default Re: Noise Behind Gauages (1989CivicSi)
hmmm... so what ur saying is maybe some sort of "gears" or the actual speedo cable or what have u within the cluster itself are just not lubbed or whatever?
the speedo cable looked ok when i popped the cluster out the other day... i even ran my car up on jack stands and it made the noise... i have no clue what it is and neither does my honda gearhead friend.... if u think of what ur brain farting on lemme know... thanks
Old Jan 24, 2006 | 07:44 PM
Could be, I know someone who got a nice car really really cheap because of the "old car cluster squeal." All he did was replace the cluster and it was fine. Maybe some other HT members can chime in on this subject.
Old Jan 24, 2006 | 07:58 PM
88crx-si's Avatar
it could be the speedometer cable. the cable goes from the transmission to the speedometer and turns faster as the car moves faster. maybe the cable needs replacing or maybe it just needs some lube on the end where it meets the speedometer..
Old Jan 24, 2006 | 08:02 PM
saikouEF8's Avatar
Default Re: (88crx-si)
good idea....howveer...i could be wrong but the end of that looks like an electronic jack of some sort... not tryin to be a pain in the ***, but im asking where would i lube the thing? i appreciate the responses guys...
Old Jan 24, 2006 | 10:31 PM
31flavorscivic's Avatar
Default Re: (saikouEF8)
I have a bad speedo cable and it does that squeak. The faster I go the worse it gets.
Old Jan 24, 2006 | 10:55 PM
Tyson's Avatar
pull the speedo cable off from the back of the guage cluster. squirt some wd40 in there. apply some grease where you can. that should do it. plug it back in.
Old Jan 26, 2006 | 08:41 PM
saikouEF8's Avatar
gracias
Walterronny
Jul 28, 2015 04:19 PM
DBada FM
Apr 2, 2013 09:05 AM
Charlie Moua
19
Sep 19, 2011 10:30 AM
peanut butter
Feb 18, 2008 04:00 PM
90ZCREX
Feb 16, 2005 01:35 PM
