Code 43 Fuel Supply system....Need help!!!
Old Jan 24, 2006 | 07:16 PM
Hawaii Da9's Avatar
Default Code 43 Fuel Supply system....Need help!!!
I have encountered a Fuel Supply System code on my Ls/Vtec motor. wat are some possible causes or fixes i can do about it.. If any one knows anything an can help me out, it would be helpful ok Thank you
Old Jan 24, 2006 | 07:25 PM
RedSiHatch's Avatar
Default Re: Code 43 Fuel Supply system....Need help!!! (Hawaii Da9)
My car had the same problem, i was reading what one of my friends sent me, he is a dealer technician for honda and it says it can be some short in some wires to the injectors or to the ecu, the ecu might be bad (try getting someone else's, a donor ecu, and try it out and see if you get the code, and/or the O2 sensor is bad, if you need some more info i can get you the print-out with exact instructions on what to do, you can e-mail me redsihatch@yahoo.com.
Old Jan 25, 2006 | 09:53 AM
Hawaii Da9's Avatar
Default Re: Code 43 Fuel Supply system....Need help!!! (RedSiHatch)
Hey man thanks i'll try it out an c if anything helps out...but thanks for the advice...i'll get back to u on this one..
Old Jan 25, 2006 | 12:07 PM
Copy Cat's Avatar
did you ever find out what your problem was?
Old Jan 26, 2006 | 12:31 AM
Hawaii Da9's Avatar
Default Re: Code 43 Fuel Supply system....Need help!!! (CivicFerioViRs)
Did not fined out yet but when i do i'll let u know
Old Feb 21, 2006 | 04:20 PM
Turbo_Mike's Avatar
Anybody figure this out yet? I popped the code 43 2 or 3 times in the last week, and my recent 00 ls swap has been running rough since i put it in.
Old Feb 21, 2006 | 06:10 PM
turbod92si's Avatar
possible it could be your fuel pump not sending out enough fuel or the filter on the pump is clogged. check and see what your pressure is at. make sure that you're up to date on your maint.
Old Feb 21, 2006 | 06:22 PM
HamiltonRex's Avatar
Default Re: Code 43 Fuel Supply system....Need help!!! (turbod92si)
make sure you fuel system is in good working order.. possibly your fuel filter.
I throw the code once every few months.. When i shut her down, and start it back up its gone for awhile.
Old Feb 21, 2006 | 06:46 PM
lobudgetr's Avatar
Default Re: Code 43 Fuel Supply system....Need help!!! (HamiltonRex)
My civic and integra both used to get that hair up their asses every once in a while. but mine went away.
Old Feb 22, 2006 | 03:34 PM
EE_Chris's Avatar
It could be:
1. the O2 sensor itself
2. the a/f mixture that it's sensing is outta whack compared to what the ECU wants to see
3. the wiring
Old Feb 24, 2006 | 07:03 AM
Turbo_Mike's Avatar
Default Re: Code 43 Fuel Supply system....Need help!!! (EE_Chris)
ttt, code hasnt come back in a week, but car is running much worse
Old Feb 24, 2006 | 08:12 AM
EE_Chris's Avatar
Default Re: Code 43 Fuel Supply system....Need help!!! (MIKE JONES)
What help can we be with no info from you? 00 LS swap isn't nearly enough to go off of...
xtegx
Mar 19, 2010 12:39 PM
SsB_Db8
Jul 14, 2007 11:25 PM
ImThatGuy
Jul 8, 2005 08:02 AM
Senbonzakura
Jan 26, 2005 05:52 PM
Hondasaurs
Dec 13, 2002 10:42 AM
