Couple questions on DA's.
Anyone ever get a leak through the auto seatbelt track? I'm narrowing down everything for the infamous passenger side leak, but water is dripping from the auto seatbelt track mostly on the driver side onto the window switches.
I have a fully rebuilt motor with a XTD stage 1 clutch and resurfaced flywheel. When I first started driving it when everything was installed it like... vibrated, but some people told me this was normal and it just had to break in. Well I got used to it, but I still want to know what it is cause it's over 2k miles and when I downshift slowly. like at lower RPMs my whole frontend of my car like vibrates, anyone know what i'm talking about?
Also, the climate control works fine, except for the fan speed, 1 2 and 3 work but as soon as I switch it to 4 it's like a kill switch?
EDIT - Another thing, anyone have a cricket sound when their heat's on? It's not constant, when I turn sometimes and sometimes just random.
Any info on any of these is much appreciated. TIA
Modified by 93_teg_CT at 8:44 PM 1/25/2006
well the engine one....maybe they didnt tigthen the mounts enough and causing it to vibrate...buy that mount that connects your engine to the chassis..forgot what its called though
do you have a sunroof?
make sure the sunroof isnt leaking.
otherwise, if water is leaking and dripping down onto the switches, its not the infamous 'passenger side leak' as it does not leak through the windows. its leaks right above the heater motor.
uhm.... yea, check the window seals as well as the sunroof for leaks.
crapanese
Sep 14, 2008 01:33 PM
luder22
Oct 22, 2004 09:19 PM
