TDC w/ GE Cam Gears & Valve Adjustment w/ S2S2 Cams
Old Jan 24, 2006 | 05:38 PM
SiBuddy00's Avatar
Default TDC w/ GE Cam Gears & Valve Adjustment w/ S2S2 Cams
Hello, While I was aligning TDC with the GE gears, i wanted to be sure I was aligning the correct lines. There are solid lines like stock gears, along with a dotted line. I was just kinda wondering what the dotted line was for. I have included a picture, just to make sure they're set at TDC. The 0 degree markings for each gear looks to be pointing at a slightly different angle... Whereas the stock gears UP arrow normally both are shooting at the same angle..
My second question is... adjusting the valves.. The motor is fresh and I have the gears set at stock timing. I'm going to dyno before adjusting the timing. I was wondering... should I adjust the valves with stock timing, dyno, adjust, then readjust the valves again? Right now with the stock timing, I ran the feelers through and its pretty tight. I'm planning on adjusting to Blox's measurements which show a lil more loose than stock measurings. Thanks!
Old Jan 24, 2006 | 06:08 PM
Runnerdown's Avatar
Default Re: TDC w/ GE Cam Gears & Valve Adjustment w/ S2S2 Cams (SiBuddy00)
Yes the cam gears are set correctly.
Adjust the valves now, as per bloxs instructions. After the motor has run for a few hundred miles, check and re- adjust them as necessary.
Old Jan 28, 2006 | 04:58 PM
SiBuddy00's Avatar
Default Re: TDC w/ GE Cam Gears & Valve Adjustment w/ S2S2 Cams (Runnerdown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown &raquo;</TD></TR><TR><TD CLASS="quote">Yes the cam gears are set correctly.
Adjust the valves now, as per bloxs instructions. After the motor has run for a few hundred miles, check and re- adjust them as necessary.</TD></TR></TABLE>
Alrighty thats the plan as of now, if I could just get a second opinion for reinsurance. Thanks!
Old Feb 13, 2006 | 02:57 PM
SiBuddy00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiBuddy00 &raquo;</TD></TR><TR><TD CLASS="quote">Alrighty thats the plan as of now, if I could just get a second opinion for reinsurance. Thanks!</TD></TR></TABLE>
aznboi_2
Apr 14, 2009 10:37 AM
Takumi Fujiwara
Jan 18, 2006 09:49 PM
hlhneast
Mar 1, 2004 08:54 PM
travis
Mar 11, 2002 05:21 PM
