90-93 guage cluster wiring diagram
Old Jan 24, 2006 | 04:17 PM
donaldmejr's Avatar
Default 90-93 guage cluster wiring diagram
I need a 90-93 wiring diagram for the guage cluster or at least a pic of what every pin/wire is?? tried to search but no luck thanks
Modified by donaldmejr at 5:49 PM 1/24/2006
Old Jan 24, 2006 | 04:30 PM
bks84's Avatar
Loved
g2ic.com
Old Jan 24, 2006 | 04:50 PM
donaldmejr's Avatar
Default Re: (4sd4dr)
nothing off that site
links please or pics
Old Jan 24, 2006 | 05:34 PM
bks84's Avatar
Loved
did you search the site. i did, and i found this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">90-93 integra ls pinout
PIN Wire Color Wire Function
A1 Yellow/Red Seat Belt Reminder Light
A2 Green/Red Parking Brake Switch Light
A3 Green/Black Hatch Open Indicator Light
A4 Green/Red Low Fuel Indicator Light
A5 Yellow/White Fuel Gauge
A6 Yellow/Red ECM, Trans Control, Moduel TCM, Cruise Unit, VSS
A7 Red Gauge Lights, Dash Light Dim
A8 Empty
A9 Red/Black Gauge Lights
A10 Green/Yellow Right Turn Signal Indicator
B1 Green/Blue Left Turn Signal Indicator
B2 Red/Blue High Beam Indicator
B3 Blue/Red ABS Indicator Light
B4 Blue Tachometer
B5 Green/Red Door Open Indicator Light
B6 Yellow/Green Engine Coolant Temp Gauge
B7 Black Ground
B8 Yellow Ignition Power
B9 Green/Orange Malfunction Indicator (Ck Eng.) Light
B10 Black/Yellow Charging Sysem
B11 White/Blue Charging System (Battery) Light
B12 Yellow/Red Low Engine Oil Pressure Light
C1 Red Cruise Control Unit
C2 Red/Black Gauge Lights - Cruise Control Dimming Circuit
C3 Empty
C4 Empty
C5 Black Cruise Control Ground
C6 Empty
C7 Yellow Ignition Power for Cruise Control Unit</TD></TR></TABLE>
holy crap, 10 second serach for "integra guage pin"
Old Jan 20, 2021 | 10:23 PM
Jayden Sinclair's Avatar
Default Re: 90-93 guage cluster wiring diagram
Is this for 90-93 da6 or da9 cos I haven't seen one with cruise controle an I am trying to remove the cable driven speedo
Tims Toy 500
Apr 20, 2011 04:27 AM
JdM_RACeR07
Aug 20, 2006 07:01 PM
quis84
Feb 7, 2006 10:14 AM
Gumbey75
Mar 25, 2005 08:20 PM
uneek4dr
Dec 20, 2002 07:55 AM
