phearable.net chippin Q
Old Jan 24, 2006 | 02:19 PM
gnar kill's Avatar
Default phearable.net chippin Q
I was lookin into getting a chip from them for my socketed p28....now I have a crx with the stock si tranny and I was thinkin about having them put in a 2 step launch controller since it is free. But do our cars have a speed sensor which is needed for this option to be used? since our cars have a cable that goes from the tranny to the tach unlike the newer cars that have an actual speed sensor.
Also I would like to know a little more input on how well that launch controller works from someone who has one. thanx
Old Jan 24, 2006 | 02:37 PM
drdisco69's Avatar
Default Re: phearable.net chippin Q (gnar kill)
The cluster has a vss that sends the signal to the ecu. Otherwise vtec and all the other things that depend on speed wouldn't work.
The launch control works well, I use it on my PR3 in my crx. It's a fuel cut and not an ignition cut, so sometimes it takes some time to get used to. Light throttle is the best, just to keep it bumping on the limiter. Putting your foot farther in makes the engine fall farther in rpm between each "bump", and you may get a bog when you let the clutch out. The best part of the feature is if you never use it, it's like it's not even there.
Old Jan 24, 2006 | 07:32 PM
gnar kill's Avatar
Default Re: phearable.net chippin Q (drdisco69)
any suggestions of what I should set my rev limiter at
d16z6
si tranny
zex 59300 cam
zex valve springs
y8 intake mani
b18 TB
I was thinkin maybe 3500??
wfocrx
Apr 21, 2006 10:07 AM
mikenme
17
Apr 8, 2004 08:39 PM
JDM CRX
Oct 20, 2002 10:54 PM
Malgerus
Jun 6, 2002 01:56 AM
rice4life
May 14, 2002 07:24 PM
