hybrid brake setups?
Old Jan 24, 2006 | 01:05 PM
i heart honda's Avatar
Default hybrid brake setups?
I know a lot of guys are doing different brake setups off of other hondas on eg's ek's and such. are there hybrid setups that we can use on our ef's? i have 16" rota gt3's and am really only worried about upgrading the caliper since i have brembo slotted and cross drilled rotors. I will upgrade again if need be.
Old Jan 24, 2006 | 01:57 PM
DC_RaceR's Avatar
Default Re: hybrid brake setups? (bOOstd GSX)
you could use the DA brake system.
Old Jan 24, 2006 | 11:27 PM
x_outlaw_x's Avatar
about that...will the rear disc's from a da bolt up or will i have to swap out the whole suspension?
Old Jan 25, 2006 | 12:01 AM
cr-x-91's Avatar
yes, they bolt right in. the rear and the front. ive used 91 ex front brakes and MC, and the rear were si disc. If u have a crx u need the ebrake cables from a crx si, and if u have a hatch than u can use the DA cables.
Old Jan 25, 2006 | 04:40 AM
Default Re: (cr-x-91)
should i use the DA rotors and calipers
Old Jan 25, 2006 | 08:46 AM
Default Re: (bOOstd GSX)
i read somewhere that you can replace the whole front knuckle with the gsr unit is this true? that would make my life easier because then i get get gsr calipers and rotors.
Old Jan 25, 2006 | 11:41 AM
spcrxracer's Avatar
https://honda-tech.com/zerothread?id=1171175&page=1
Old Jan 25, 2006 | 12:36 PM
Default Re: (spcrxracer)
wayne, i was actually looking at you car today on teamrice.org... and thanks for the link.
just plain sick man. keep up the good work.
if you got any pics send em to nitrousrush@gmail.com
Old Jan 31, 2006 | 01:37 AM
Redline96LX's Avatar
* B A N N E D *
Please read this....
https://honda-tech.com/zerothread?id=1437507
If you want to upgrade hybrid wise, PM me.
Old Jan 31, 2006 | 04:04 AM
dagimp415's Avatar
My friend talked about early-model accord wagon calipers b/c their the same as the ITR/CTR. Then look for aftermarket rotorrs for that model.
Old Jan 31, 2006 | 06:52 AM
CRX Toad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline96LX &raquo;</TD></TR><TR><TD CLASS="quote">Please read this....
If you want to upgrade hybrid wise, PM me.</TD></TR></TABLE>
Cross drilled rotors do nothing. I have used them they didn't help. This was track test too.
05Bodyssey
Sep 5, 2017 12:42 PM
blazzer
10
Feb 27, 2010 10:43 AM
webrex
Oct 9, 2006 03:54 PM
blundar
Suspension & Brakes
Aug 18, 2005 08:17 AM
bseriesboosted
Sep 22, 2003 08:30 PM
