unburnt fuel?
Old Jan 24, 2006 | 01:03 PM
Komakazi_830's Avatar
Default unburnt fuel?
hey,
the back of my car has black stuff all over it. it is there even after driving less than 50 miles. my car is stock and the air filter is 3000 miles old. anyone have any ideas?
Old Jan 24, 2006 | 01:19 PM
The Weather Man's Avatar
black stuff................
by any chance did you try that seafoam stuff?
You could be running extremely rich for some reason.......
Old Jan 24, 2006 | 01:25 PM
lude98SH's Avatar
Default Re: (TheKINGPin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheKINGPin &raquo;</TD></TR><TR><TD CLASS="quote">black stuff................
What would seafoam do ? Destroy the rings. Ive heard its safe though. But i have used it and i didnt really see a difference besides the fact that it clogged my o2 sensors. I got my compression checked after i used it ...150 in all 4. Im not sure if it was like that before though. I should have had it checked prior. Anyway now my idle is funny im not sure if that has anything to do with the seafoam.
Old Jan 24, 2006 | 04:04 PM
blackdelslo's Avatar
Default Re: (lude98SH)
Seafoam cleans and does a damn good job of it. Why didn't you take out your 02 sensors before running it throught your car?
Old Jan 24, 2006 | 04:12 PM
Default Re: (delLudeVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delLudeVTEC &raquo;</TD></TR><TR><TD CLASS="quote">Seafoam cleans and does a damn good job of it. Why didn't you take out your 02 sensors before running it throught your car?</TD></TR></TABLE>
Yeah. And I've heard that after using the seafoam - the black **** will come out of the exhaust for a few days.......its supposed to loosen the baked on dirt and grime.
Old Jan 24, 2006 | 04:44 PM
plikit's Avatar
i get black crap on my back bumper too. you definitely get some from hitting vtec. but i think my car does need to be tuned.
Old Jan 24, 2006 | 10:04 PM
lude98SH's Avatar
That makes alot of sense now but i checked all the threads and nobody mentioned it. Also on the can itself it says o2 sensor safe. But i guess that means the product is safe, not the carbon that it breaks up. Anyway i cleaned the o2 sensors and they worked fine after.
Old Jan 25, 2006 | 10:29 AM
kulrevon's Avatar
how did you clean the o2 sensors?
Old Jan 25, 2006 | 10:41 AM
951dc5's Avatar
Default Re: (kulrevon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulrevon &raquo;</TD></TR><TR><TD CLASS="quote">how did you clean the o2 sensors?</TD></TR></TABLE>
yeah i wonder the same? hit me if u found the answer to it
Old Jan 25, 2006 | 11:16 AM
brolli's Avatar
Default Re: (Prelude951)
are you sure its not like burnt oil?
brolli's Avatar
Default Re: (brolli)
hey try painting the car black. i bet that will take care of the problem.
Old Jan 25, 2006 | 11:27 AM
IHateJDM's Avatar
carb cleaner
black **** on your bumper is common for modified cars. is your car 100% stock, meaning nothing modified, only maintenance work with oem parts?
Old Jan 25, 2006 | 12:31 PM
Default Re: (IHateJDM)
yea only regular maintanence except i bought it with bum clutch so i changed the disk, bearing, and flywheel which were all OEM cept the flywheel is Fidanza. i dont really use vtec either. i still have no idea wuts causing it. any1 got ne more ideas?
Old Jan 25, 2006 | 01:18 PM
Perfectionist's Avatar
Depending on what it's contaminated with, some have had a little success hitting the element with a MAP gas torch flame.
Old Jan 25, 2006 | 02:59 PM
lude98SH's Avatar
I used a torch. Ive actually heard carb cleaner is not safe.
Old Jan 27, 2006 | 11:07 AM
yea id rather not have to clean my sensors...ill hold off on the seafoam for now...im gonna change the air filter tomorrow. should i try fuel injector cleaner?...this is still pissin me off ne more ideas?
Wes90civic
13
Jan 1, 2004 02:56 PM
integra-modder
Nov 17, 2003 06:50 AM
DC2_Integra
Apr 10, 2003 11:47 AM
