Can i put teins off an EK coupe on my 89 hatch si?
Yes. But you will need to get the whole spring and shock setup. You will also need to get the 92+ front shock fork to fit the bigger shock bottom but that's it.
The only problem is if your getting the tein lowering springs and not coilovers you will not have the same drop due to the difference in weight.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Freeltec »</TD></TR><TR><TD CLASS="quote">will there be any handling affects when usings forks from a 92+ and omni full coil overs from a 96-00 civic ride/ height wise etc??</TD></TR></TABLE>
No negative handling affects.
beef-cake
10
Mar 22, 2007 02:04 PM
StickyGreen
Dec 31, 2005 09:59 PM
icefirezero
Nov 22, 2004 11:21 AM
dextR
Feb 23, 2004 06:54 PM
b18c1guy
Sep 7, 2003 02:02 PM
