Guys! My car is trippin. please help me out
Old Jan 24, 2006 | 11:35 AM
bb4socal's Avatar
Default Guys! My car is trippin. please help me out
SO i just dropped a h22 in the lude. Just took it to the muffler shop this morning to get the exhuast extended, ect etc. Im on my way home and the car droppes in rpms to about 3 or 4 hundred and when i press on the gas it slows down even more. I pull ove and it wont start. I wait 15 minutes, try to start it again and it turns over, butonce again its idleing really low to the point of diing. what could be wrong guys please help. All my hard work is crumbling on me....what do you guys think it is???
Old Jan 24, 2006 | 01:18 PM
bb4socal's Avatar
They crank still moves..thats good news right? It still seems to have compression.
Old Jan 24, 2006 | 01:20 PM
The Weather Man's Avatar
What else did they touch?
Its kinda weird that something like that would happen.........maybe they put a rag or something in your exhaust did you **** them off?
Old Jan 24, 2006 | 01:37 PM
Chuckles99SH's Avatar
Default Re: (TheKINGPin)
How long did it run before it died? Did it make any sounds before it bogged down and died?
Old Jan 24, 2006 | 01:46 PM
bb4socal's Avatar
Default Re: (Chuckles99SH)
no no i did not **** them off...its a great reputible shop. A business friend if anything
anyways...um. i would have to say no i t didnt make any weird noises. Juss one thing...my dumb *** wasnt paying attention and let it hit the rev limiter for a second and then thats when it started to bog and slow it self down. I know im stupid for not paying attention, when i try to turn it over it doesnt make any weird clanking noises liek soemthigns brokin.
Should i check cel light??
Old Jan 24, 2006 | 01:51 PM
y0whuddupb's Avatar
Default Re: (bb4socal)
idle adjusted correct? was it driving fine before you went to the muffler shop?
Old Jan 24, 2006 | 01:55 PM
bb4socal's Avatar
yeah it was driving okay i assume. im sure there was a few things to tweek here and there. idle adjuster screw is on.
Old Jan 24, 2006 | 02:02 PM
bb4socal's Avatar
ok guys i juss checked the CEL and the light permanetly stays on. That means its not detecting any problem right? If theres no problem that the car itself is not finding what can i do next??
Old Jan 24, 2006 | 02:49 PM
prelittlelude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4socal &raquo;</TD></TR><TR><TD CLASS="quote">ok guys i juss checked the CEL and the light permanetly stays on. That means its not detecting any problem right? If theres no problem that the car itself is not finding what can i do next??</TD></TR></TABLE>
to my knowledge if you check the CEL code and the light stays solid your ecu has a major internal error. if your jumping the service connector and then turn the ignition on and it stays lit up your showing a code 0 which is a ecu malfunction.
Old Jan 24, 2006 | 03:39 PM
bb4socal's Avatar
actually i dont think so. Ive read a couple write ups, and they state that if the cel stays lit there are NO problems. I believe if the CEL light shuts off the ECU is the problem. Anyoen else have an opinion?
Also i took the valve cover off and looked at the belt, it looks like the timing belt wants to role off. What could cause that?? This week im gogin to chnage the mual tensioner and the timing belt to be sure. Anythign else to check?
Old Jan 24, 2006 | 03:46 PM
ludesrv's Avatar
CEL comes on when theres a problem.
Old Jan 24, 2006 | 03:51 PM
bubs's Avatar
If you have the service connector shorted out, turn the ignition key on, and the CEL stays lit, there's something wrong with the ECU. Check out a helms manual.
I'd start by pulling the negative battery terminal or the clock/radio fuse to reset the ECU. If that doesn't work, check your wiring or try a different ECU.
Good luck
Old Jan 24, 2006 | 03:55 PM
blackdelslo's Avatar
Default Re: (ludesrv)
Soooooo what your trying to tell us is that when the light comes on, there is no problems but if the light goes off there is a problem? You have that twisted.
If the light comes on at all there IS a problem. The check engine will flash the code to you but if it just stays on then the ecu is not working correctly. If the light comes on and then shortly turns off and stays off then there is no problem, it is telling you that the ecu is reporting errors correctly.
p.s.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Ive read a couple write ups, and they state that if the cel stays lit there are NO problems. I believe if the CEL light shuts off the ECU is the problem.</TD></TR></TABLE>
That is the most rediculous statement ever, if there is no problems the ****** light doesnt come on! Think of what you are saying. The light coming on and then turning off is the ecu checking for and errors like i previously stated, how can it do that if its broken? it cant, it stays lit.
Old Jan 24, 2006 | 05:53 PM
bb4socal's Avatar
Default Re: (delLudeVTEC)
guys im just telling you what i read..
heres the link to where i read about the Light staying on.
http://www.superhonda.com/foru...44813
Number 6 states what i was saying. i have an h23 ecu can i try with that??
Old Jan 24, 2006 | 07:00 PM
bb4socal's Avatar
ok so i hooked up the old ecu(h23) and the CEL light(with service cnnector jumped) still stays on. And im, sure that theres nothing wrong with that ecu. Corect me if im wrong, but does the ECu erase its memory of any past ISSUes when you reset the ECU via radio fuse or pulling battery plug? Cuz i reset the ecu before doing the service connector diagnosis. Would that defeat the perpose of finding out the COde that its throwing?
Old Jan 24, 2006 | 07:08 PM
mgags7's Avatar
check your map sensor first....
but a solid CEL is a bad ecu....period....
you could have blown a fuse or something....check it all....random stuff can go wrong....
teggy25
Oct 2, 2008 12:02 PM
AnDy327
Oct 26, 2007 12:26 PM
dcdcdc
Oct 14, 2007 06:10 PM
