removing stock headunit
Does anybody have an easy way on how to do this, do i need to flathead screwdrivers to get it out, or should I unbolt anything else, I should have just paid to get this done
When I installed an aftermarket Head Unit, I had to take out everything starting from the arm rest console.
There is an article over at Team Integra that shows you the details on how to go about taking the HU out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kupras »</TD></TR><TR><TD CLASS="quote">Does anybody have an easy way on how to do this, do i need to flathead screwdrivers to get it out, or should I unbolt anything else, I should have just paid to get this done</TD></TR></TABLE>
Nah dont pay for the labor....
http://www.team-integra.net/se...D=115
You need Philips head screwdrivers, and ya, you gotta start with the arm rest, then the shifter housing & ashtray. It's seems like a lot, but it it doesn't take too long.
Seach T-I for a how to article...or click on the link above...
I'm not sure if you have to remove the center console pieces. You can get the radio to slide out by removing the (2) 8mm bolts. It's a question of whether you can unclip the radio harness, antenna, and possibly a CD changer DIN plug without removing the center console. I've never done it that way, but it looks feasible.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justa_Old_DC2 »</TD></TR><TR><TD CLASS="quote">http://www.team-integra.net/se...D=115</TD></TR></TABLE>
whatever you do, don't follow the install instructions from this article, just the removal instructions.
if you do it right, i'll look like this, and be as secure as stock:
^ my install.
in case you're interested, this is how i put it together:
^ drew that for someone else 5 months ago, seems applicable here.
^ my install.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SW33TDUDE »</TD></TR><TR><TD CLASS="quote">
What is this mount strap and where can I get one? I have a problem with my aftermarket radio because it is not securely in place, I bet this will solve the problem!</TD></TR></TABLE>
they sell metal strips of that at any hardware store..or just any strip of metal that you drill your own hole in
well i attempted to get the unit out, got to the part where the 2 bolts were remaning i wound up cutting myself and could not find a socket wrench big enough so i am w/o a radio. I might as well just purchase a new headunit acura refuses to give out the code with the vin number unless you have the serial but for the price they are offering i might invest in a aftermarket unit, thanks though for the help guys!
TeamNextGenChris
Audio / Security / Video
Oct 23, 2004 07:29 PM
