1995 Del sol si built ls vtec for turbo
1995 Del sol SI
Bottom End
Ls Block
Ls crank
Acl Rod Bearings
Oem Main Bearings
Scat H Beam Rods w/ Arp Rod Bolts
Mahle 9:1 Compression Pistons
Mahle Piston Rings
B16 Vtec Water Pump
B16 Vtec Oil Pump
Gsr Timing Belt
Fresh Hone
Turbo Tapped Ls Oil Pan
New Oil pan Gasket
New Front Main Seal
New Rear Main Seal
Unorthadox Racing Crank Pulley
Arp Headstuds
New Oem Headgasket Modified for Ls vtec
Ls vtec dowel pins
Transmission/Mounts/Axles
1996 Gsr Transmission
Act 6 puck Unsprung Disk
Act Heavy Duty Pressure Plate
Fidanza 8lb Flywheel
Gsr Driver Mount post
Gsr Driver Mount with Insert
Rear Mount with insert
Rear b16 T Bracket
Auto-Manual Transmission Mount
Del sol B16 oem shift linkage
Shift linkage urathane bushings
short shifter
Driveshop Stage 1 axles
Gsr Intermediate Shaft
Head
B16 Pr3-2 Vtec Head
Aebs Intake Manifold
Hayame Fuel Rail
Hayame Fuel pressure Gauge and Modifier
New Gsr Distributor
Fresh Head Resurface
Interior
Mint Del Sol Seats
Momo steering wheel
del sol momo steering wheel hub
momo shift ****
boost gauge mounted in circle vent
air/fuel gauge mounted in other circle vent
mint interior
Socketed / Chipped p28 ecu
Exterior/ Suspension
Del sol Spoke wheels painted black
Tail lights professional resprayed red (like jdm ones)
weapon r coilovers in front
ebay coilovers in rear
Car is painted black....pretty good condition no dents...trunk needs to be glossed
Car needs a Engine wire harness
tkaing offers.............
Bottom End
Ls Block
Ls crank
Acl Rod Bearings
Oem Main Bearings
Mahle Piston Rings
B16 Vtec Water Pump
B16 Vtec Oil Pump
Gsr Timing Belt
Fresh Hone
New Oil pan Gasket
New Front Main Seal
New Rear Main Seal
Arp Headstuds
Ls vtec dowel pins
Rear b16 T Bracket
short shifter
Head
B16 Pr3-2 Vtec Head
Hayame Fuel Rail
New Gsr Distributor
Interior
Mint Del Sol Seats
Momo steering wheel
momo shift ****
mint interior
b16 HEAD 400$$ with extras/Built Ls block (9:1 comp) 1000/ TRANNY/AXLES/EVERYTHING DIRT CHEAP!!!!! I
hotimportcrx
Northeast (Sales)
12
May 7, 2006 04:29 PM
