how do i fix this?
Old Jan 24, 2006 | 08:20 AM
hondatuner20's Avatar
Default how do i fix this?
my wheels are pointed in. how do i fix this? my car is lowered on tokico shocks and springs.
Old Jan 24, 2006 | 08:23 AM
Pee Wee's Avatar
Default Re: how do i fix this? (hondatuner20)
alignment
Old Jan 24, 2006 | 08:25 AM
ludesrv's Avatar
Get it alligned, if that doesnt work, skunk 2 makes a nice adjustable upper control arm, or you know, a no name brand camber kit will do the trick.
Old Jan 24, 2006 | 09:05 AM
Keebler's Avatar
Default Re: (ludesrv)
Skunk2 doesnt make one for EF's. I think ingalls is the only manufacturer of a camber kit for the EF.
But yes, get an alignment and camber kit if its too much for you. New bushings and ball joints will help also.
Old Jan 24, 2006 | 09:12 AM
purplecrx's Avatar
Just so you know, what you have is called "camber." But like the others said, if an alignment can't adjust them back to straight you may need an Ingall's alignment kit. I recommend IconAutoparts.com for that.
Old Jan 24, 2006 | 11:44 AM
VeilSide_Mas's Avatar
what kind of springs and tokico shocks did u use if u dont mind me asking as i would like to lower my car too
Old Jan 24, 2006 | 12:27 PM
88crxhfb16's Avatar
Ingalls adjustable ball joints, i had to replace upper control arms to use them on my ef though.
http://www.ingallseng.com/cars/honda.html
this is what your looking for.
Old Jan 24, 2006 | 12:31 PM
rice a roni's Avatar
omg that must be negative camber!!!
negatic camber veiwed from the front /---\
positive camber veiwed from the front \---/
positive toe veiwed from the top /---\
negative toe veiwed from the top \---/
negative camber and positive toe produce wear on the inner side of the tire wheres positive camber and negative toe produce wear on the outside of the tire.
that camber doesnt look bad. its good for cornering anyways, just get your toe adjusted a tad bit negative to equal out the odd wear thats going to happen on your vehicle.
Old Jan 24, 2006 | 12:51 PM
crx_88_si's Avatar
in the back you can use washers and longer bolts on the upper control arms.
also, you can raise the car a bit
Old Jan 24, 2006 | 01:18 PM
REDBARON's Avatar
Default Re: (crx_88_si)
You will need to get a camber kit if you want them to be back in the middle. Honda's do not have an adjustment for camber from stock so an alignment will not fix it. You can do the longer bolt and washer trick for the rear but you will have to get some kind of camber adjutment for the fronts to get them back to 0.
Old Jan 24, 2006 | 01:41 PM
Default Re: (VeilSide_Mas)
they are actually tokico's brand of spring.
Old Jan 24, 2006 | 01:53 PM
will this work for the front.
http://cgi.ebay.com/ebaymotors...ZWDVW
Old Jan 24, 2006 | 04:44 PM
REDBARON's Avatar
Default Re: (hondatuner20)
Yes. I have the same kind except mine are Ingalls.
Old Jan 25, 2006 | 05:13 AM
Default Re: (REDBARON)
thanks what should i buy for the rear.
Old Jan 25, 2006 | 07:43 AM
88crxhfb16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondatuner20 &raquo;</TD></TR><TR><TD CLASS="quote">thanks what should i buy for the rear.</TD></TR></TABLE>
nothing the rear should be fine. have U look at the rear yet??
Old Jan 25, 2006 | 08:48 AM
Default Re: (88crxhfb16)
they look straight but i didnt know if it was just an illusion and they were really off.
Old Jan 25, 2006 | 08:53 AM
kcjohnnyboy's Avatar
i got some ebay camber kit for the front but the crx fender liner, there is this lip on the inside that limits you from setting the camber all the way positive....the upper control arm will hit the lip
Old Jan 25, 2006 | 09:27 AM
Default Re: (kcjohnnyboy)
does it hit if your just setting it back to 0?
Old Jan 25, 2006 | 10:18 AM
ludesrv's Avatar
My prelude sits on ingalls! I will vouch for there quality part!
Old Jan 25, 2006 | 11:03 AM
88crxhfb16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kcjohnnyboy &raquo;</TD></TR><TR><TD CLASS="quote">i got some ebay camber kit for the front but the crx fender liner, there is this lip on the inside that limits you from setting the camber all the way positive....the upper control arm will hit the lip</TD></TR></TABLE>thus, U need the adjustable Ball joints
Old Jan 25, 2006 | 11:08 AM
Jonny Black's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crxhfb16 &raquo;</TD></TR><TR><TD CLASS="quote">Ingalls adjustable ball joints, i had to replace upper control arms to use them on my ef though.
On 88-89 EFs honda welded in the balljoints..so changing the upper arm would be needed in order to use the Ingalls balljoints. But if you have an earlier honda then no problem.
Also Ingalls does not sell to the consumer, so please visit us at http://www.ICONautoparts.com
and check out our many Ebay sales.
Old Jan 25, 2006 | 11:57 AM
88crxhfb16's Avatar
Default Re: (Jonny Black)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonny Black &raquo;</TD></TR><TR><TD CLASS="quote">
and check out our many Ebay sales. </TD></TR></TABLE>
heres a link to the exact part:
http://www.iconautoparts.com/c...store
Old Jan 25, 2006 | 12:21 PM
what upper arms would i need.
Old Jan 25, 2006 | 12:53 PM
Jonathan_ED3's Avatar
Old Jan 25, 2006 | 01:25 PM
Default Re: (Jonathan_ED3)
anybody know where i can find them online.
