Honda S2000 Honda S2000
buzzing sound on deceleration in low gear
Old Jan 24, 2006 | 07:52 AM
TL1000R's Avatar
Default buzzing sound on deceleration in low gear
I've noticed a buzzing sound only when decelerating in 1st through 3rd gear from mid to high RPMs. It sounds like it's coming from the middle of the car, not the rear end. Anyone else experienced this? 2001 with 40k. It's definately a driveline noise though.
Modified by TL1000R at 11:09 AM 1/24/2006
Old Jan 24, 2006 | 08:14 AM
timg's Avatar
Probably the clutch rattle. It's common and there's a TSB on it.
Tim
Old Jan 24, 2006 | 08:24 AM
TL1000R's Avatar
Default Re: (timg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timg &raquo;</TD></TR><TR><TD CLASS="quote">Probably the clutch rattle. It's common and there's a TSB on it.
Tim</TD></TR></TABLE>TSB??
Old Jan 24, 2006 | 08:51 AM
papa5murf's Avatar
Default Re: (TL1000R)
normal
Old Jan 24, 2006 | 08:58 AM
Francesco's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TL1000R &raquo;</TD></TR><TR><TD CLASS="quote">TSB??</TD></TR></TABLE>
Technical Service Bulletin
Old Jan 24, 2006 | 11:11 AM
Mocky57's Avatar
Default Re: (Francesco)
check on s2ki.. they have all the TSBs.. or call your dealership and they should have the TSB on file. It happened on my '01 as well.
Old Jan 24, 2006 | 01:08 PM
Jspectyper's Avatar
Default Re: (Mocky57)
mine has it
Old Jan 24, 2006 | 05:23 PM
pwrofdrm's Avatar
Default Re: (Jspectyper)
Mine has it too...It's nothing to worry about, it's not damaging. The springs in the clutch disk just vibrate at certain RPM's under deaccelleration.
It's starting to get the best of me...I'll be replacing my clutch soon.
Old Jan 25, 2006 | 09:30 AM
Scot's Avatar
Default Re: buzzing sound on deceleration in low gear (TL1000R)
try turning your stereo up
not sure if honda will honor a TSB after the warranty is expired. worth a shot though! Call your dealer and ask.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TL1000R &raquo;</TD></TR><TR><TD CLASS="quote">I've noticed a buzzing sound only when decelerating in 1st through 3rd gear from mid to high RPMs. It sounds like it's coming from the middle of the car, not the rear end. Anyone else experienced this? 2001 with 40k. It's definately a driveline noise though.
Modified by TL1000R at 11:09 AM 1/24/2006</TD></TR></TABLE>
Old Jan 25, 2006 | 11:34 AM
TL1000R's Avatar
Default Re: (.no tork.)
[So if I replace the the clutch, it will cure the problem? Stock or aftermarket?
PostIt
Honda Civic (2006 - 2015)
13
Nov 8, 2007 06:14 AM
john457
Feb 8, 2006 01:27 PM
NerveAgent
Honda S2000
Feb 6, 2006 01:35 AM
ludecanada
Jan 10, 2006 05:50 AM
spicoli
Oct 4, 2004 09:42 AM
