D16a1 Swap!! Engine Mount Help!!!
Okay i got a 90 dx hatchy and a d16a1 engine that im trying to swap into it ... everything its almost done except for one more problem ... timing belt side engine mount is different ... would appriecate some quick help.. thnkxz
Pull the mount bracket off and replace with mount bracket that came out of the car...(mount attatches to this, you will need to pull off your timing covers) should line up fine
i think thats what we tried doing
we took the timming covers off and tried attaching the other mount but they didnt aling...
.... let me grab my camera and get a picture...
[IMG][/IMG]
Modified by MANDO6669 at 10:30 PM 1/23/2006
Modified by MANDO6669 at 10:32 PM 1/23/2006
[IMG][/IMG]
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MANDO6669 »</TD></TR><TR><TD CLASS="quote">aight okay ... so where can i get some custom mounts at?</TD></TR></TABLE>
I have no idea..Most people dont do that swap in 88-91 cars..They do bolt into the 84-87 cars though..
Screw you guys, I'm... going... home.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MANDO6669 »</TD></TR><TR><TD CLASS="quote">aight i got the pictures up.... am i being dumb .. and doing some stupid thing wrong???
anybody?</TD></TR></TABLE>Well, sorry to have to tell you this, but the one big thing you did wrong was NOT doing your homework before choosing an engine for your swap. In very simple terms you can think of Civics/CRXs as the following: 84-87 Civics/CRXs & 86-89 Integras (your D16A1) are Gen. A; and 88+ Civics/CRXs are Gen. B; and the twain shall never mix (mostly). It's a royal PITA to put a D16A1 into any 88+ civic because all of the mounts are different, and because there are much better/easier/more powerful engines to swap in like the D16Z6 and the D16Y8, which is why NOBODY makes mounts to do this swap. Either buy a welder and make your own mounts, or sell your engine/tranny on ebay or http://www.redpepperracing.com or http://www.g1teg.org , and then buy a better engine to swap into your 90 hatch. I'm not saying that what you're attempting CAN'T be done, just that you'll waste an enormous amount of time and energy doing it for a mediocre result. Good luck with that. Post more questions if you have them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tjbizzo »</TD></TR><TR><TD CLASS="quote">Well, sorry to have to tell you this, but the one big thing you did wrong was NOT doing your homework before choosing an engine for your swap. In very simple terms you can think of Civics/CRXs as the following: 84-87 Civics/CRXs & 86-89 Integras (your D16A1) are Gen. A; and 88+ Civics/CRXs are Gen. B; and the twain shall never mix (mostly). It's a royal PITA to put a D16A1 into any 88+ civic because all of the mounts are different, and because there are much better/easier/more powerful engines to swap in like the D16Z6 and the D16Y8, which is why NOBODY makes mounts to do this swap. Either buy a welder and make your own mounts, or sell your engine/tranny on ebay or http://www.redpepperracing.com or http://www.g1teg.org , and then buy a better engine to swap into your 90 hatch. I'm not saying that what you're attempting CAN'T be done, just that you'll waste an enormous amount of time and energy doing it for a mediocre result. Good luck with that. Post more questions if you have them. </TD></TR></TABLE>
yyyep basically
yyyep basically
a guy on hcf has this in his 4dr ef. if you would like to continue with the swap an auto starter is also needed as the manual doesnt throw out enough to engage the flywheel. HCF-honda civic forums .......edited for TJ
Modified by finalimpact at 10:26 AM 1/24/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by finalimpact »</TD></TR><TR><TD CLASS="quote">
a guy on hcf has this in his 4dr ef. if you would like to continue with the swap an auto starter is also needed as the manual doesnt throw out enough to engage the flywheel. </TD></TR></TABLE>
And hcf means what exactly???
Hint:>>> a link to another site is much more useful than an unknown acronym. When posting, look for the little planet symbol above the post window right after BI<u>U</u>, although since you posted an image ok I'm sure you know where it is.
the soL that could
Welding / Fabrication
Aug 21, 2011 09:12 PM
fastcrx420
Oct 25, 2009 04:48 AM
