Hole for aftermarket Water Temp sensor??
Old Jan 23, 2006 | 08:06 PM
roller3804's Avatar
Default Hole for aftermarket Water Temp sensor??
I am looking for a spot to mount the water temp sender in the block. I want to leave the stock one though. Are there any holes that I could use to get the water temp? I searched through my FSM. I could not find any extra holes. Only the ones for the stock ECT sensors.
thanks
-camrann
Old Jan 23, 2006 | 09:25 PM
skrewdlude's Avatar
Default Re: Hole for aftermarket Water Temp sensor?? (camrann)
You can get one of these:
You can get them at Pegasus for $30, Greddy also makes one I think, but it costs a little more for the same thing.
The other option would be to tap number 11 in the picture below:
The JDM H22 is not already tapped here. You could also just buy that piece as it is only $15 from SL Honda.
Old Jan 24, 2006 | 09:54 AM
roller3804's Avatar
Default Re: Hole for aftermarket Water Temp sensor?? (skrewdlude)
awesome thanks. Do you mean like tap threads into that piece?
Old Jan 24, 2006 | 11:25 AM
skrewdlude's Avatar
Yea, you would just drill a hole, then put threads in the hole with the appropriate size tap. You would basically be making the $15 dollar stock piece, but if you have the tools it would be free
Old Jan 24, 2006 | 11:29 AM
shutta's Avatar
but if he's running jdm motor w/ usdm harness he would already have a plug in there.
Old Jan 24, 2006 | 12:43 PM
roller3804's Avatar
Default Re: (shutta)
If I had a JDM harness I could use the inlet. I have the USDM inlet that already has a sensor in it. But just the motor only
Old Jan 24, 2006 | 08:50 PM
skrewdlude's Avatar
Oh yea, I forget the P13 uses that sensor. I am running on Hondata/P28, and don't have that sensor, nor is my inlet tapped. I just ran my Greddy gauge to the stock sender's location, but you said you didn't want to do that. Sorry for the confusion
Old Jan 25, 2006 | 05:43 AM
roller3804's Avatar
Default Re: (skrewdlude)
Its all good. When I get a chipped ECU, I can just do something similar to your setup. Thanks for the help.
Old May 17, 2020 | 05:37 PM
Frankestein's Avatar
What's the size of the tap for h22A4 vtec termostat housing water temp sensor?
punkracer
Jul 4, 2010 06:55 AM
honda_boy23
Apr 21, 2008 04:17 PM
Teglove2
Jul 14, 2004 05:09 PM
ten_30
Oct 2, 2002 11:08 AM
