civic hb si
Old Jan 23, 2006 | 04:16 PM
WD40's Avatar
Default civic hb si
my power sun roof is running slow what do i do
Modified by locoridr at 5:55 PM 1/23/2006
Old Jan 23, 2006 | 04:53 PM
WD40's Avatar
my bad
Old Jan 23, 2006 | 05:16 PM
mysihatchback's Avatar
Default Re: civic hb si (locoridr)
I have a 92 civic hatchback si with a power sunroof and mine is kind of slow too. I put a little bit of grease on the track that it slides on and it helped me out some. Not sure what else to do though
Old Jan 24, 2006 | 09:26 AM
SOL Food's Avatar
most of the times it just happens due to wear/tear.
you can try greasing up the tracks to see if that helps.
Old Jan 24, 2006 | 09:51 AM
Earthworm Jim's Avatar
What do you mean by running slow?
Old Jan 24, 2006 | 10:11 AM
dohcdelsol's Avatar
Default Re: civic hb si (The_General)
over time motor just doesnt have the power.
it could also be off track a little causeing friction therefore moving slower
Old Jan 24, 2006 | 10:24 AM
ralphie14's Avatar
Default Re: civic hb si (dohcdelsol)
Mine is doing the same it opens just fine most of the time but closing is a diff. story. I got my hands on a new motor so when it get warmer I am going to pop that in and see if that will fix the issues, hopefully it will. Other than replacing the motor like others said try to grease the track and see if that helps.
Old Jan 25, 2006 | 11:14 AM
StanBo's Avatar
Default Re: civic hb si (ralphie14)
Any option for replacement?
Mine crawls open and closed so I think I will be either pulling the fuse if it has it's own circuit or unplug the controls.....
JDM FERIO RS
Honda Civic (2006 - 2015)
47
Sep 21, 2009 02:16 PM
07FG2
57
Nov 26, 2008 07:29 AM
kevyd123
Dec 3, 2007 04:38 PM
coryb8199
Mar 6, 2006 08:53 AM
