Honda S2000 Honda S2000
Whats everyone alignment settings?
Old Jan 23, 2006 | 04:07 PM
Francesco's Avatar
Default Whats everyone alignment settings?
Well since i just lowered my car, and im happy with the drop, i need to get an alignment done soon...
I was running the Euro spec in my old spa, and i liked the neutral feel it had. Im probably going to run that again, but im open to new ideas...
What are you running? Im not really worried about tire wear since i know its going to wear weird since ill be running an aggressive setup...
Old Jan 23, 2006 | 04:13 PM
S2K K1DD's Avatar
Default Re: Whats everyone alignment settings? (Francesco)
Yea same here jus lowered my car not to long ago and was curious as to what everyone else is running....Franceso how did you like the Euro settings on your old S2???
Old Jan 23, 2006 | 04:16 PM
Mr. Projekt's Avatar
* B A N N E D *
Stock AP2 camber is .6/1.3 F/R. I run at 1/1.5.
6 degrees of caster. 0 toe.
Old Jan 23, 2006 | 04:17 PM
Nishant's Avatar
Street Normal:
Front Camber: -0.5
Rear Camber: -1.5
Toe: 0 all around
Street Aggressive:
Front Camber: -1.5
Rear Camber: -2.5
Toe: 0 all around
Track Set up:
Front Camber: -1.8 to -2.0
Rear Camber: -2.8 to -3.0
Toe: 1/8 out in the front
AP1 Wheels with proper sizes S02's
Suprisingly even with my aggressive street set up, I was getting pretty even tire wear. It prob has something to do with my driving style though
Frank, you will have to ask people to list what wheels and tires sizes they are using. This will have a significant impact on alignment. (rubbing issues, etc...)
Old Jan 23, 2006 | 04:18 PM
* B A N N E D *
Default Re: Whats everyone alignment settings? (Nishant)
He has an AP2 now thread *****.
Old Jan 23, 2006 | 04:21 PM
S2K K1DD's Avatar
Default Re: Whats everyone alignment settings? (Slideways2000)
im trying not to get to much camber wear and also have a nuetral feel...as close to stock....when it comes to Toe Camber etc... i get lost so what do you guys suggest
Old Jan 23, 2006 | 04:34 PM
Francesco's Avatar
Default Re: Whats everyone alignment settings? (S2K K1DD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2K K1DD &raquo;</TD></TR><TR><TD CLASS="quote">Yea same here jus lowered my car not to long ago and was curious as to what everyone else is running....Franceso how did you like the Euro settings on your old S2???</TD></TR></TABLE>
it felt really neutral, but it also came out of alignment faster than stock...
Old Jan 23, 2006 | 04:42 PM
S2K K1DD's Avatar
how often did you have to get an allignment done??
Old Jan 23, 2006 | 05:03 PM
Francesco's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2K K1DD &raquo;</TD></TR><TR><TD CLASS="quote">how often did you have to get an allignment done??</TD></TR></TABLE>
i had it done 2 or 3 times...
Old Jan 23, 2006 | 05:13 PM
S2K K1DD's Avatar
Did you go to the dealer for your allignment??
Old Jan 23, 2006 | 05:30 PM
Nishant's Avatar
NTB for alignments if you know someone who works there or if they have a competent mechanic.
i have the 3yr deal for which i paid $120. I have already had 10+ alignments, money well spent
Old Jan 23, 2006 | 07:40 PM
Francesco's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2K K1DD &raquo;</TD></TR><TR><TD CLASS="quote">Did you go to the dealer for your allignment??</TD></TR></TABLE>
Susman Acura...
this one tech their does my work since my other one left...
Old Jan 24, 2006 | 02:58 PM
aklucsarits's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant &raquo;</TD></TR><TR><TD CLASS="quote">Street Normal:
Front Camber: -0.5
Rear Camber: -1.5
Toe: 0 all around
Street Aggressive:
Front Camber: -1.5
Rear Camber: -2.5
Toe: 0 all around
Track Set up:
Frank, you will have to ask people to list what wheels and tires sizes they are using. This will have a significant impact on alignment. (rubbing issues, etc...)</TD></TR></TABLE>
You got good tire life because you have no rear toe in on any of your configurations. Camber is not really what kills tires quickly. It's toe that causes the most wear. The Stock alignment parameters call for a lot of toe-in (3/8" toe-in I think?). If you run 1/4" toe in or 1/8" toe in, you'll get more life out the expensive rear tires. If you run 0 toe in the rear, you'll get even more tire life, but I would not recommend that for novices, because the rear end will be pretty willing to come around with 0 toe.
Andrew
Old Jan 25, 2006 | 05:29 AM
Francesco's Avatar
Default Re: Whats everyone alignment settings? (aklucsarits)
im going to compare this with the euro specs once i get home and look them up...
Street Aggressive:
Front Camber: -1.5
Rear Camber: -2.5
Toe: 0 all around
Old Jan 25, 2006 | 06:34 AM
papa5murf's Avatar
^ uk specs is..
FRONT CAMBER -1.0 DEGREE
FRONT CASTER 6.45 DEGREE
FRONT TOE 0.0 DEGREE
REAR CAMBER -2.0 DEGREE
REAR TOE 0.20 DEGREE
Old Jan 25, 2006 | 09:16 AM
Francesco's Avatar
Default Re: Whats everyone alignment settings? (papa5murf)
what specs are you running Dylan?
i want to run -1.5 front and -2.0 rear...im just not sure what castor i wan't
Old Jan 25, 2006 | 09:24 AM
papa5murf's Avatar
i'm running uk alignment.. but with 2.3 camber in the rear....
i'm going to be having my car re-aligned sometime next week... so i'll get you final numbers when thats done...
Old Jan 25, 2006 | 07:16 PM
Francesco's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf &raquo;</TD></TR><TR><TD CLASS="quote">i'm running uk alignment.. but with 2.3 camber in the rear....
i'm going to be having my car re-aligned sometime next week... so i'll get you final numbers when thats done...</TD></TR></TABLE>
thanks...i need to get mine done soon...
Old Jan 26, 2006 | 07:44 AM
papa5murf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco &raquo;</TD></TR><TR><TD CLASS="quote">
thanks...i need to get mine done soon...</TD></TR></TABLE>
i'm actually getting it done later today.. so i'll have numbers tonight..
Old Jan 26, 2006 | 08:00 AM
Francesco's Avatar
i'm actually getting it done later today.. so i'll have numbers tonight..</TD></TR></TABLE>
you the man now i can get mine done on monday
Old Jan 26, 2006 | 11:27 AM
S2K K1DD's Avatar
dam i have no idea want kinda of allignment i should get i jus want even tire wear and car to handle nuetral
Old Jan 26, 2006 | 02:37 PM
papa5murf's Avatar
you the man now i can get mine done on monday </TD></TR></TABLE>
alright.. here's my new specs... i gave the guy the uk specs but some of the specs he needed to change cause he wasn't able to get those specs cause of my drop....
front camber -1
caster 8.20 degrees
toe 0
rear camber -2.6
toe 20 degrees
total toe 40 degrees
my short impression on it... i like it... it's rather neutral at the moment on those long sweeping turns.. car feels planted.. i haven't taken any hard turns yet... but i will by the weekends end....
Old Jan 26, 2006 | 02:54 PM
S2K K1DD's Avatar
can i get a copy of those UK spec??
Old Jan 26, 2006 | 02:57 PM
papa5murf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2K K1DD &raquo;</TD></TR><TR><TD CLASS="quote">can i get a copy of those UK spec??</TD></TR></TABLE>
i posted it earlier.. it's above.. but here it is again...
Old Jan 26, 2006 | 10:54 PM
Francesco's Avatar
front camber -1
caster 8.20 degrees
toe 0
rear camber -2.6
toe 20 degrees
my short impression on it... i like it... it's rather neutral at the moment on those long sweeping turns.. car feels planted.. i haven't taken any hard turns yet... but i will by the weekends end.... </TD></TR></TABLE>
i go monday at 2pm, ill try it out...
hey Dylan, on a personaly note. what do you think i should do with my rims? i have them sold for 2,300$ with tires if i give the final ok...i just don't know what to buy...
work meister 1 3pc. only come in 18, but they would be nice in gold/polished...now i just saw prodrive makes a gold rim, but im not sure where to buy them from...
