weird problem... probably a relay
Old Jan 23, 2006 | 04:04 PM
labatt50's Avatar
Default weird problem... probably a relay
Ok,
My car is an accord ex-r 93 5 speed.
Problem: Sometimes my car won't start
Thing i found weird: my battery is full but the car won't crank, i hear the fuel pump, if i jump the car it will start without any hesitation. When i turn the key and it doesn't start... i just have to repeat, off on off on off on... and it will start sometime (usually within one minute) but after it smell burn (d'oh!) if i turn the key and hold it, i hear a tick tick tick tick tick tick... under the dash but it doesn't come from the main relay cause i though it was the problem but its not, the click come from another place under. Also if i put the key to on and jump the starter, i work also...
so i think it could be the switch or a relay... if you can help me that woul be cool
Old Jan 23, 2006 | 04:30 PM
P_Adams's Avatar
Default Re: weird problem... probably a relay (labatt50)
Have a "load test" performed on your Battery (it may be "Full" as you call it) but it may not be able to give up it's charge.
Remove, properly clean and reattach both your Positive+ and Negative- Battery cables and Battery Terminals.
They are acting as high-resistance connectors, allowing enough amps thru to power all but the starter.
The 'clicking" you're hearing from under the dash is most likely the Starter Solenoid 'chattering" from insufficient power.
P
Old Jan 23, 2006 | 06:55 PM
labatt50's Avatar
Default Re: weird problem... probably a relay (P_Adams)
thank for your answer:
i did check the battery and its fine, i even took my crx battery and its the the same thing.
its dark outside so i'll check again tomorrow
Old Jan 23, 2006 | 06:59 PM
YeuEmMaiMai's Avatar
bang on the starter when it won't crank and see of it cranks after that. IF it does, repalce starter.
Old Jan 23, 2006 | 07:23 PM
labatt50's Avatar
Default Re: weird problem... probably a relay (YeuEmMaiMai)
i know its not the starter cause if i jump the starter it crank ans start right away
i hate doing this... i look like a thief
Old Jan 23, 2006 | 07:31 PM
could still be the starter since the starter now has access to more amperage to crank it over.
Old Jan 23, 2006 | 07:49 PM
labatt50's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">could still be the starter since the starter now has access to more amperage to crank it over.</TD></TR></TABLE>
reconsidering what you said... it could be the problem..
reno96teg
Apr 23, 2008 01:52 PM
EGk3nrock
15
Aug 29, 2007 01:00 PM
D50boy
Acura TL, RL & ZDX
14
Aug 16, 2007 04:35 AM
g-ride-si
Jan 13, 2006 08:14 AM
junkyardRx
15
Apr 26, 2004 03:04 AM
