Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
Towing with the Ridgeline.
Old Jan 23, 2006 | 02:47 PM
Daishi's Avatar
Default Towing with the Ridgeline.
My buddy is entering his highly modified Mazdaspeed Protege into HIN Chicago, and we were thinking about using my Ridgeline to trailer it there. I think it's capable, but I'm wondering if anyone has towed different vehicles with one, and their opinions/suggestions.
Old Jan 24, 2006 | 03:50 PM
genetsang's Avatar
Default Re: Towing with the Ridgeline. (Daishi)
are you considering towing the car with a hitch/trailer?
from honda.com
STANDARD TOWING FEATURES:
• Pre-wired for 4- and 7-pin connectors
• Pre-wired for trailer brake controller
• Heavy-duty radiator with dual 160-watt fans
• Heavy-duty power steering fluid cooler
• Heavy-duty ATF cooler
• Huge front and rear brake rotors
• Closed-box frame with unit-body construction
5,000-lb. towing capacity<U></U>
you do the math. your mazda weighs in 3000lbs MAX. the Ridgeline can tow 5k lbs... i dont think a hitch/trailer will weigh anywhere close to 2000 lbs.
Old Jan 25, 2006 | 06:16 AM
stick's Avatar
u should be fine towing the vehicle but look in ur owners manual as to ur what gear u should drive in. i think its D3.
livinlow
Dec 15, 2006 10:47 AM
itr561
Jun 17, 2004 01:59 PM
professorman
Jan 4, 2004 01:08 AM
erniecars
Sep 23, 2003 01:06 PM
calcanio
Feb 11, 2002 07:43 PM
