boring out sleeved z6
Old Jan 23, 2006 | 02:44 PM
CRX_Phantom1's Avatar
Default boring out sleeved z6
what is the max I can bore a sleeved z6 to? i was told that 78mm will give me a 1.8L motor. can I go any bigger or is that about it? I have this posted in the tech. forum but no one has responded so i figured i would try here
Old Jan 23, 2006 | 02:59 PM
Default Re: boring out sleeved z6 (CRX_Phantom1)
bump...anyone know or anyone know who i can ask?
Old Jan 24, 2006 | 04:36 AM
StorminMatt's Avatar
I believe 78mm or maybe 79mm is as big as you can go. You might want to talk to someone who does resleeving to find out.
Old Jan 24, 2006 | 06:42 AM
Hamstr323's Avatar
Default Re: boring out sleeved z6 (StorminMatt)
ASK BISI
Old Jan 27, 2006 | 04:20 AM
Bisimoto's Avatar
Default Re: boring out sleeved z6 (Hamstr323)
We have gone up to 79mm, but the 78 gave us the best performance and sealing. I hope that helps. Let me know if I can be of further assistance.
Old Jan 27, 2006 | 08:01 AM
hybridmoments's Avatar
Default boring out sleeved z6 (CRX_Phantom1)
78mm will only give you 1720 cc.
i was planning on this same build also. i was told 78mm is really the safest max bore, and that would be on a race engine.
DH-Racing.com said 79-81mm bore. ("81 mm is for allmotor ")
Sean at ERL Performance said "The Darton MID’s that we use to sleeve the D series blocks can be bored out to a max bore of 78mm."
Vince at Golden Eagle said "To sleeve your D16 block would run $850 up to 79 mm. I always suggest going a bit smaller than that in case you ever need to re-hone the block for any reason. "
81mm would give you 1855cc
79mm would give you 1764cc
77mm bore will give you 1676cc
kinda interested in the new SOHC in the base model 2006 civics . already 1.8L
• 1.8-liter, SOHC i-VTEC® 4-cylinder engine
• 140 horsepower @ 6300 rpm
• 128 lb.-ft. of torque @ 4300 rpm
wonder if that could be sleeved and bored to like 2.0 liter
Old Jan 28, 2006 | 09:10 PM
Hamstr323's Avatar
Default Re: boring out sleeved z6 (Bisimoto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bisimoto &raquo;</TD></TR><TR><TD CLASS="quote">We have gone up to 79mm, but the 78 gave us the best performance and sealing. I hope that helps. Let me know if I can be of further assistance.</TD></TR></TABLE>
the single cam master has spoken
94d16zdvtec
10
May 2, 2008 10:27 AM
Turbo_y8
Feb 15, 2006 10:26 AM
CRX_Phantom1
Jan 24, 2006 04:43 AM
drowzysleeper
Mar 28, 2005 08:43 AM
