H22a in civic only b series injectors will work in it
Old Jan 23, 2006 | 02:01 PM
spoonzdelsol's Avatar
Default H22a in civic only b series injectors will work in it
I am wondering why this is I have tried stock H22 injectors but want work . Vtec want engage on car with them in it but with the b series it engages fine just wondering what the deal is .
Old Jan 23, 2006 | 02:05 PM
Cute EK's Avatar
Default Re: H22a in civic only b series injectors will work in it (spoonzdelsol)
Does the fuel system cut out in the higher rpms at WOT? My friend is having that problem, as well as the vtec not engaging. BTW try the hybrid forum for this.
Old Jan 23, 2006 | 02:06 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: H22a in civic only b series injectors will work in it (Cute EK)
dont h series injectors require a resistor box? never done an H swap but ohm the injectors, if you get 2-3 ohms they need a resistor. if they are 12-13 like your civic injectors should be, then you dont. but if you are using the civic injectors w/o a box and it runs, and the h series need a box and dont have one, i would start there. unless i dont know what i am talking about, which i may not, then ignore me.
Old Jan 23, 2006 | 02:11 PM
IHateJDM's Avatar
Default Re: H22a in civic only b series injectors will work in it (boostedcivicsir)
[QUOTE=boostedcivicsir]dont h series injectors require a resistor box? [QUOTE]
yep, obd1 h22 injectors (345 cc) need a resistor box. the obd2 H injectors (290 cc) do not.
Old Jan 23, 2006 | 04:03 PM
MrMike's Avatar
Default Re: H22a in civic only b series injectors will work in it (IHateJDM)
OBD1 H22 uses peak and hold injectors which require a resistor box wired into your wiring harness. Civic, integra, and OBD2 prelude use saturated injectors which use regular 12V ignition.
black0hatch
Jan 28, 2011 05:27 PM
1qukcb7
Mar 14, 2010 02:50 PM
B Dap
Jun 30, 2009 07:59 AM
jdm_option2
Jan 20, 2009 10:36 AM
majerst
May 13, 2007 05:29 PM
