lost my brakes, WTF?
Old Jan 23, 2006 | 01:55 PM
91_civicsi's Avatar
Default lost my brakes, WTF?
Brand new master cylinder put in about 2 weeks ago, full brake fluid in resevoir
i was driving on the way home from work today, some lady slammed her brakes on in front of me, so i go to do the same, my foot goes all the way to the floor and i hear a really loud popping sound and then i pull over open the hood, then there is no brake fluid in the resevoir and i have no brakes now WTF is going on!!!
car is a 91 civic hatch si
Old Jan 23, 2006 | 01:58 PM
Boosted Chemist's Avatar
Default Re: lost my brakes, WTF? (91_civicsi)
simple either you didnt bleed all of the air out or there is a leak.
Old Jan 23, 2006 | 02:20 PM
thesmogman's Avatar
That loud pop was a seal. It could be the master cyl or the rear drum cyl's seals
You should see some brake fluid somewhere. That will get you close. If you don't add some more fluid and pump it through. Then look for it. It has to go somewhere.
You should not lose all of your brakes if it is the wheel cyl. So I bet it's the master cyl.
Old Jan 23, 2006 | 02:28 PM
91_civicsi's Avatar
the master cyl after 2 weeks? like they aren't COMPLETELY gone but VERY VERY SHITTY, like barely stop
Old Jan 23, 2006 | 02:31 PM
Tyson's Avatar
Default Re: (91_civicsi)
have your whole brake system checked out. look for leaks especially.
Old Jan 23, 2006 | 02:36 PM
racerxadam's Avatar
if you add fluid and it leaks out and you still can't find the leak unbolt the master cylinder and see if the fluid is making its way into the booster.
Old Jan 26, 2006 | 10:22 PM
91_civicsi's Avatar
i busted a brake line, thanks guys
Old Jan 26, 2006 | 10:50 PM
31flavorscivic's Avatar
lol thought you meant your calipers literally fell off and you couldn't find them.
(i did that once. not my proudest moment ever, but nevertheless it happened.)
Old Jan 27, 2006 | 12:31 AM
I heart My EF Sedan's Avatar
Default Re: (31flavorscivic)
now you have a reason to upgrade to some ss lines... i would since you're already changing them...
mrspeedy69
15
Aug 5, 2013 02:57 AM
lxdriver
Dec 17, 2011 10:23 PM
douglaslovin
Nov 26, 2009 11:41 AM
Harleyfxdl80
Oct 1, 2006 05:20 PM
grenthang
11
Nov 15, 2004 09:08 PM
