b16 brake system shaking like a mofo
i have a problem with the brake system it chakes really really bad does any one have any idea y or had had this problem before i changed the fallowing
.civic 90 to 91 hub for axle fit
.passager caliper
.both disk brake
.brake pads
.pasanger side tide rod end
.driver side lower balljoint
does the tie rod end change on 88 to 91
please help me if u can
.passager caliper
.both disk brake
.brake pads
no but i dnt think alingment can be the problem but i will just to make shure
thanks for the tip any one else please give me some hints
you need to check the runout on the rotors, if you can get a runout gauge you will remove the wheels and then thread the lugnuts back on to hold the rotor tight against the hub. set the gauge up on the rotor surface and then spin the rotor and see how much runout you have. there is a spec for max runout buy i'm not sure exactly how much it is.
what do u mean exacly plus i forgot to add that my brake dont work i have no i dea y i took em to a shop to get em debleed but they dint work lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic889802 »</TD></TR><TR><TD CLASS="quote">what do u mean exacly plus i forgot to add that my brake dont work i have no i dea y i took em to a shop to get em debleed but they dint work lol </TD></TR></TABLE>
IT is SOOOO hard to read your posts, PLEASE spell check because this makes my head hurt! From what I could make out of your broken english it sounds like warped brake rotors, not much else will cause your problem unless something is just not installed right. You could also have a bad wheel bearing. i am not sure what else it could be but if you type more clearly we may be able to help you out better
well when i speed up driver side shakes
when i stop the stering wheel shakes real bad plus my brakes dont seem to work some one help
yep u got warped rotors.. replace those and pads...and when u say ur brakes don't work?? do u mean it goes all the way to the floor?? u need to give more info in order for us to help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic889802 »</TD></TR><TR><TD CLASS="quote">when i start braking the car shakes alot when i go fast it chakes too i ran out of ideas</TD></TR></TABLE>
If you have no brake pedal you have air in the lines, bleed the entire system to make sure it's good. If it still goes to the floor then your master cylinder is bad (assuming there are no leaks in the brake lines). If your car shakes under acceleration it has nothing to do with your brakes and sounds like another problem all together. A bad axle or wheel bearing is the most likely cause of your vibration under accleration, checking all that should almost definetely fix your problems, good luck!
It is also possible that your steering rack is bad if everything else checks out but I would check that after everything else.
trooper0641
Dec 29, 2007 11:25 AM
sugarloafpkwy
14
Dec 4, 2005 07:31 PM
