will del sol shocks fit on a da
I need to know if del sol shocks will fit in the shock forks for a da. My uncle has a set and I want to know if they will fit. Also if they will are there any other things I need to look out for.
They may fit but you'll probably have different spring rates, so most likely the shocks either won't be as tall or won't be stiff enough because they were intended to hold up a lighter car. In case you're wondering, I put the springs from an integra on my CRX once and it sat up like a 4X4 so that's where I drew the conclusion that it won't work for you so I could be wrong but I doubt it.
I was acutally thinking more of the springs than the shocks. Hell you could try it, maybe just do the back ones as a test. Do you have a spring compressor? Don't even consider trying it if not.
White cracker yeehaa
Dec 19, 2005 08:03 PM
champwhitedelsol
10
Sep 15, 2005 09:39 AM
del.soul.
Oct 9, 2003 01:46 PM
