2001 Accord H22 Swap...What Distributor
hello, i'm doing an H22 swap into 2001 coupe, and need to know what distributor to use, I am using the accord harness on the H22 engine. I currently have the TD-89u from H22 but ir will not plug in, it has a 10 pin connector, and the car harness has a 4 pin connector. the engine is in the car and all mounted and hooked up, but just can't figure out the dizzy
You can rewire the accord dizzy.
http://www.superhonda.com/foru...pp=15
Read the wiring table on that page.
Good luck with the swap bro, make sure you post pics after
My accord will be under the knife very soon for the same swap.
