fs: jery built motor/818 so cal
Top end:
'98 USDM ITR head
Custom competition headwork by Alaniz
Jun III cams
Skunk2 cam gears
OBDII GSR distributor
TWM 50mm ITBs
TWM fuel rail, regualtor, gauge
Hondata plastic intake gasket
RC 440cc fuel injectors
SMS 4-1 header
NGK spark plug wires
NGK spark plugs
JDM ITR valve cover
JG oil cap
Bottom end:
B18C1 w/ RS Machines sleeves
B18B crank
B18B Eagle rods notched for B18C bearings
JE 12:5 pistons
Clutchmasters Alum Flywheel
ACT 6 puck clutch
Tranny:
USDM ITR tranny w/ LSD
JDM 4.78 FD
ECU: p72 w/ crome
misc: poly insert motor mounts, oil catch can, new oil pump, water pump, timing belt oem honda brand new koyo race radiator and samco hoses. motor has very very low miles and has a base map for it to run but needs dyno time for full power. like i said this set up can make power and was built by jerry, just needs to be tuned................asking 5,300. for an 11 sec motor.
'98 USDM ITR head
Jun III cams
Skunk2 cam gears
TWM 50mm ITBs
SMS 4-1 header
NGK spark plugs
JDM ITR valve cover
JG oil cap
Bottom end:
B18B crank
JE 12:5 pistons
ACT 6 puck clutch
Tranny:
JDM 4.78 FD
ECU: p72 w/ crome
Made I should scrap my B16 build and just throw this in. What did it do on the dyno with that base map? Any leaks or issues that would need to be addressed before throwing this in a daily driver?
no leaks, no issues, before i put on the new injectors, old ones were 270, it pulled 225whp. This was a jerry built motor, the **** is strong, and pulls hard. It only has 1000 miles on the motor and tranny, so its still fresh as expletive. I upgraded the injectors, and switched over to uberdata to get it tuned. Never got around to it, had issues that came up, so i have to sell it.
redman223
105
Aug 31, 2011 12:35 PM
