power steering question
Old Jan 23, 2006 | 09:29 AM
BlueLude 94's Avatar
Default power steering question
I just put power steering fluid back into my car after puting the power steering pump back in my car. HOw long should it take for the fluid to run through out the system?
Old Jan 23, 2006 | 09:30 AM
shutta's Avatar
when you start the car, turn left and right a bunch of times from lock to lock and then check the fluid again. you shoudl be good after that.
Old Jan 23, 2006 | 10:03 AM
Default Re: (shutta)
iv done that and i have also drove around my neighborhood a lil bit. It seems to be a s tad bit stiff still when im driving around 20mph but then when i slow down for a turn or when im at a stop its realy stiff.
Old Jan 23, 2006 | 10:08 AM
shutta's Avatar
check the belt tension. is it squealing or anything?
Old Jan 23, 2006 | 10:59 AM
could it be too tight? Cuz we did adjust those.
Old Jan 23, 2006 | 01:48 PM
Default Re: (BlueLude 94)
K i actualy just needed more power steering fluid but now i face another problem. the problem is that now when the car is running the sound makes this weird noise. i dont know if its cuz its pumping the fluid in or if there is too much fluid.
Old Jan 23, 2006 | 07:18 PM
Shaggy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueLude 94 &raquo;</TD></TR><TR><TD CLASS="quote">K i actualy just needed more power steering fluid but now i face another problem. the problem is that now when the car is running the sound makes this weird noise. i dont know if its cuz its pumping the fluid in or if there is too much fluid.</TD></TR></TABLE>
Can you describe the noise?
Old Jan 23, 2006 | 09:28 PM
hu's Avatar
hu
If its a screeching noise, it is probably a belt.
Old Jan 24, 2006 | 03:24 AM
Default Re: (hu)
It doesnt really sounds like a screeching noise. It only happens after I put more than a certain abount of power steering fluid in it. It sounds like the pump is sucking or pushing somehting. its hard to describe.
Old Jan 24, 2006 | 06:22 AM
shutta's Avatar
well check to see if you have too much fluid in there. if you do you'll have to get some out some how.
Old Jan 24, 2006 | 06:47 AM
mgags7's Avatar
you cant have too much fluid, the reservoir would overflow
you probably just have a bunch of air in the system, let it work its way out....
Old Jan 24, 2006 | 10:49 AM
onefastrx7turbo's Avatar
Default Re: (mgags7)
yes! bleed the system. you can do it on the ground but I had mine on jackstands. run the engine and keep turning the wheel back and forth, lock to lock. keep doing that for about 5-8 times. the longer your pump cavitates, the more damage is done. if it runs long enough with air, it will start to sound like a ford power steering pump all the time and you will have to buy a new one.
Old Jan 24, 2006 | 10:50 AM
Default Re: (onefastrx7turbo)
also make sure you are using honda power steering fluid! the wrong fluid will mess $hit up.
Old Jan 24, 2006 | 11:18 AM
Yeah I got honda certified fluid which is good for all hondas it says.
Mishako129
May 11, 2013 01:06 AM
davidzil
Honda CR-V & Element
Apr 15, 2013 10:16 AM
h23siaws
Jan 23, 2009 05:58 AM
nek0
Sep 25, 2003 08:06 AM
Soulless
Dec 31, 2002 01:36 PM
