K-Series Scatter Shield? Production yet or all custom?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedDreamz.com »</TD></TR><TR><TD CLASS="quote">I used the deist b series and rolled it around till the buckles were at the bottom. worked fine.</TD></TR></TABLE>
Where can I get one and how much?
Steve
Steve
I was reviewing the rules and if I'm REQUIRED to have a trans blanket, then I don't think I need a scatter shield. Am I wrong?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">
All FWD or transverse-mounted applications using a clutch and
running quicker than 11.99 must be equipped with a flywheel
shield made of 1/4-inch-minimum-thickness steel plate. In lieu of
steel plate, an SFI Spec 4.1 blanket will be accepted if blanket
adequately covers bellhousing. Shield must surround the
bellhousing completely except for area of flywheel shield adjacent
to differential and axle shaft. Shield may be multi-piece, with pieces
bolted together using minimum 3/8-inch-diameter Grade 5 or M10
class 8.8 bolts; may be attached to engine and/or bellhousing. See
General Regulations 2:5, 2:6, 2:9, 2:10.
Steve
Modified by k-series at 3:57 PM 1/23/2006
Steve
metal b series scatter shield.
