tps sensor for b18 swap into my dx rex
Old Jan 23, 2006 | 05:55 AM
v8hnta's Avatar
Default tps sensor for b18 swap into my dx rex
does anyone know if a tps sensor of a d16 or d15 motor will work for my b18? the one on the b18 is missing. thanks
Old Jan 23, 2006 | 05:56 AM
boostinaintez's Avatar
Default Re: tps sensor for b18 swap into my dx rex (v8hnta)
ya pretty sure it will just as long as it fits in there okay
Old Jan 23, 2006 | 06:19 AM
crxnj's Avatar
Default Re: tps sensor for b18 swap into my dx rex (boostinaintez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v8hnta &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know if a tps sensor of a d16 or d15 motor will work for my b18? the one on the b18 is missing. thanks </TD></TR></TABLE>
You have to specify,,Because if its off of a dpfi d15 then it wont work,,Even if you switch the wires around it won't work,,But if its off a mpfi motor then it will work,,you may have to lengthen the tps wires..And to get the tps off the old tb you dave dremel slots in the bolts so you can fit in a screwdriver or whatever..
B!^A@
Aug 10, 2006 09:17 PM
PrettyLakesBoy
Mar 15, 2005 03:21 PM
shadowstylz
Aug 19, 2003 06:31 PM
Vtecless212
12
Mar 27, 2003 06:48 PM
