horns broken
did you check the fuse?
you might be able to get it reaching through the grille if you have teeny hands, but not from under the car; the lower part of the bumper will be in the way. it's not that hard to take it off anyway, so you might as well.
a little too easy actually... I got my GSR (factory alarm) as a theft recovery that had been stripped out. when I got it all back together i discovered the horn wasn't working, looked around and the wire to the horn had been snipped. I guess the theives reached down and snipped the horn wire, so when they smashed in the window the alarm couldn't do anything.
are there any tricks/special tools to take off those bumper bolts??? those things r made cheap an strip everytime i try to turn em. anything i can do to get them off safely?
JustHere4ADay
23
Dec 31, 2007 11:20 AM
